10
I want to remove completely Sublime Text 3 from my system. I have tried this:
sudo apt-get purge sublime-text-installer
and the application is gone, but when I install it again...
sudo apt-get install sublime-text-installer
...the themes and the plugins remain installed.
I found my own solution. The configuration packages and other data where under $HOME/.config/sublime-text-3. Once I removed that folder, all was golden.
The full answer is the combination of both the methods.
This folder really contains all the Sublime text 3 settings for the current user:
Folders structure may be like this:
Backup
Cache
Index
Installed Packages
Local
Packages
But to remove it completely you will need to call:
sudo apt-get purge --auto-remove sublime-text-installer
or
sudo apt-get remove --auto-remove sublime-text-installer
Then to install again you would call
sudo add-apt-repository ppa:webupd8team/sublime-text-3
sudo apt-get update
prosti
  • 1,085
This is what worked successfully for me:
First, I removed the sublime text package and any other dependant packages which are no longer needed from my Ubuntu:
Then I deleted the configuration and data files of sublime text and it's dependencies from Ubuntu
This is the main output of the last command which I believe interests you more:
Do you want to continue? [Y/n] y
(Reading database ... 369782 files and directories currently installed.)
Removing sublime-text-installer (3114-2~webupd8~0) ...
Purging configuration files for sublime-text-installer (3114-2~webupd8~0) ...
