I'm facing the following problem while I run update in my terminal. I am using Ubuntu 12.04.
W: Duplicate sources.list entry http://archive.canonical.com/ubuntu/ precise/partner i386 Packages (/var/lib/apt/lists/archive.canonical.com_ubuntu_dists_precise_partner_binary-i386_Packages)
W: You may want to run apt-get update to correct these problems
bummi
  • 394
I think you have one incompatible source available.
To check whether your system architecture is 32 or 64 bit, Enter the following in the terminal.
uname -i
If you are running a 32 bit system, the output will be: i386
Thus, for a 32bit system, open your sources.list file with gedit:
gksudo gedit /etc/apt/sources.list
and completely remove any line that contains amd64 Packages.
Apparently, for a 64-bit system remove the line that contains the i386 packages.
After you have edited your sources.list, saved it, and closed gedit, enter these commands:
sudo apt-get update
sudo apt-get -f install
BDRSuite
  • 3,196
  • 13
Simple Solution:
  1. Go to System Tools>Administration>Software Updater
  2. Click on Other Software tab and remove tick from one http://archive.canonical.com/ubuntu/ precise/partner i386 Packages (/var/lib/apt/lists/archive.canonical.com_ubuntu_dists_precise_partner_binary-i386_Packages
3.Now close the window. 4. Happy updating.
