I installed ginn, and set it up so when I do a left or right four finger swipe, it sends the ctrl-alt (direction) key press to easily move between workspaces. It works, but it keeps on sending the key press, so when I make the gesture once, the workspace moves four to five times. Is there a way to change the sensitivity of the gesture, or only send the key press once the gesture is complete?
I tried messing with the wishes.xml file in /usr/share/, but it didn't help much.
This is my configuration that controls the four finger swipe
<wish gesture="Drag" fingers="4">
<action name="action3" when="finish">
<trigger prop="delta x" min="300" max="600"/>
<key modifier1="Control_L" modifier2="Alt_L">Left</key>
</action>
</wish>
<action name="action4" when="finish">
<trigger prop="delta x" min="-600" max="-300"/>
<key modifier1="Control_L" modifier2="Alt_L">Right</key>
</action>
