I logged in as root in the console and ran this : usermod -d /mirror florencia
The folder mirror is located in /mirror
Log in as root and change it back to what it was before, by running usermod -d /home/florencia florencia.
I don't know what you were trying to do exactly, but you should generally not change your home directory like that.
If everything is done correctly and you loop on login page without accessing you might just need to copy your .bashrc to your new home dir
PLEASE READ EVERYTHING BEFORE MAKING CHANGES!
here is how you want to move a "/home" directory to another drive or location.
now here is where we start doing things.
cd /
sudo mkdir mnt/
sudo mount /dev/sdXX /mnt
note: replace /dev/sdXX with the specific partition or folder destination. example: /dev/sdc1 or /home/backup
now we are going to copy the contents of things.
sudo rsync -aux /home /mnt
unmount the old partition or location
sudo umount /home
delete the old /home
rm -rf /home
get device UUID for fstab
sudo blkid
open fstab and edit
sudo nano /etc/fstab
UUID=copieduuidnumber /home ext4 defaults 0 2
note: if you are using a different filesystem then change ext4 to whatever you are using. example: ext3 or ntfs
reboot and see if things are good
sudo reboot
