(I am kind of new to Ubuntu/Linux, so sorry if this problem is already solved or is very easy to fix). Today I decided to try and install Ubuntu onto a second hard drive, so I could dual boot with Windows. Firstly, I used a USB to try and install Ubuntu; however, whenever I try and load what ever is on the USB, I get an 'Invalid Format' error message that flashes on my screen. So I then tried to use a disk instead, but to no avail. I might want to add that it does give me the options to 'Try Ubuntu', 'Install Ubuntu', and some others. However no matter what I pick it always gives me the same error...
Here is a list of my computer hardware:
CPU: Intel Core i7-4790K
GPU: Asus GeForce GTX 760
(I don't think that anything else could cause this so I skipped everything else). My monitor, which in my opinion is what is causing this, is a LG M2232D-PZ. My monitor is connected using an HDMI cable from my GPU's HDMI port. I will try and take some pictures of the problem, but I hope this is enough information to give you an idea of what's happening.
Elder Geek
  • 36,752
Try this: Select "Try Ubuntu". After the error message appears, press Ctrl+Alt+F1, which should take you to a command prompt. Type:
sudo dpkg-reconfigure xserver-xorg
and then press Enter.
This will reconfigure the X display server.
Lex1con
  • 76
