I recently had a dual boot system with Ubuntu 14.04 and Windows 8.1, separated by partition. I had to do a clean install of Ubuntu on the partition with Ubuntu on it due to some problems I had with the kernel version.
I ran boot-repair and this was the output. From my understanding (which is little), I think I deleted the windows partition with the new Ubuntu partition.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Jimenemex
  • 103
You were right, the only remains of your Windows installation is the (U)EFI partition at the beginning of the disk (vfat). The other two partitions are Ubuntu (ext4) and a swap partition. You can see it here:
Partition    Start Sector    End Sector  # of Sectors System
/dev/sda1           2,048     1,050,623     1,048,576 EFI System partition
/dev/sda2       1,050,624 1,448,605,695 1,447,555,072 Data partition (Linux)
/dev/sda3   1,448,605,696 1,465,147,391    16,541,696 Swap partition (Linux)
I'm not sure what your question is from this point, but if you haven't made a back-up of your personal data from your Windows partition, then it will be very hard (or impossible?) to recover anything, however others might know more about data recovery than I do. (If that is your question, please make it clearer in your description.)
However, if you want to reinstall Windows, you should be able to do so from an installation drive. It is usually considered harder or riskier to install Windows on top of Ubuntu, but if you manage your partitions carefully and recover GRUB at the end of the installation process, you should be able to get the job done.
To manage your partitions before installing Windows, I suggest using GParted on a live session. See this AskUbuntu question on managing partitions with GParted : How to resize partitions?
Also, for the final step, see this article on recovering GRUB: https://help.ubuntu.com/community/Grub2/Installing#Reinstalling_GRUB_2
fredg999
  • 86
GUID Partition Table detected.
Partition Start Sector End Sector # of Sectors System /dev/sda1 2,048 1,050,623 1,048,576 EFI System partition /dev/sda2 1,050,624 1,448,605,695 1,447,555,072 Data partition (Linux) /dev/sda3 1,448,605,696 1,465,147,391 16,541,696 Swap partition (Linux)
"blkid" output: ________________________________________________________________
Device UUID TYPE LABEL
/dev/sda1 13FA-FFBA vfat
/dev/sda2 cc6c7c44-7e9c-438c-a43b-1445a9414e5f ext4
/dev/sda3 37127360-f402-48ad-bcc0-7763e6cb7daa swap
According to these you no longer have a NTFS (file system used by modern Windows) partition, so chances are that you wiped out your Windows 8.1 partition.
If you want to try and list all partitions go here for some help. If you still think that you can recover something, go here.
Zaka Elab
  • 165
