Ive looked around and can't find an answer to my question. I just installed Lubuntu with a live USB and now when i try to boot the only thing i get is a black screen it appears its working but i cant see anything. I had to fix this same problem when trying to boot into try Lubuntu without installing and to fix that i had to change some parameters like nomodeset and xforcevesa. Is there a similar fix to my problem? I am sorta tech savy but new to Linux in general so any help is appreciated in advance.
GPU - 750 ti CPU - i7 - 4790k
edit - Holding shift does not enter grub either i tried thanks J. Steen
Your GRUB has been mistakenly installed on your USB stick. If you plug in your USB and restart it should work. To fix this, I used to remove the USB stick during installation when the GRUB settings popped up, went one step back then continued from there.
BlackR
  • 169
