12
How do I prevent my Ubuntu 14.10 (now 15.04) from creating and saving thumbnails for a specific folder only?
I want to tell the thumbnailer to skip over that single folder (and subfolders), but for all existing and future user accounts.
I read some answered questions about excluding a specific file type, but I need to exclude files by their location!
What I already tried is to hide the folder (renamed to .foldername), but with no luck. The folder is owned by root, by the way.
Byte Commander
  • 110,243
In addition to @Fabby answer:
  1. Install the package inoticoming
    sudo apt-get install inoticoming
  2. Create wrapper script disable_thumbnails
    #!/bin/bash
    # Create the thumbnail filename
    tn_filename=$(echo -n "file://$1/$2" | sed 's/\s/%20/g' | md5sum | awk '{print $1}')
    # Destroy the thumbnail without deleting
    find ~/.cache/thumbnails -type f -name "$tn_filename*" -print0 | while IFS= read -d '' file; do
      echo > "$file"
    done
    exit 0
  3. Make it executable
    chmod +x disable_thumbnails
  4. Kill running processes, if necessary
    killall inoticoming
  5. Watch your folder
    Avoid a trailing / for the folder names
    inoticoming "<path_to_disabled_thumbnail_folder>" <full_path_of_disable_thumbnails_script>  {} "<path_to_disabled_thumbnail_folder>" \;
There is only one problem. The changes are only visible after nautilus -q
Use inoticoming --foreground … to avoid the daemon mode, if you test the script.
A.B.
  • 92,125
To get the file name for the thumbnail, start md5sum for the original file name:
% echo -n "file:///home/user/Pictures/image%201.png" | md5sum
6e1669aea9c118cb2b7ad23fc6646c71  -
% find ~/.cache/thumbnails -type f -name "6e1669aea9c118cb2b7ad23fc6646c71*"
/home/user/.cache/thumbnails/large/6e1669aea9c118cb2b7ad23fc6646c71.png
Now remove the read permissions:
chmod -r /home/user/.cache/thumbnails/large/6e1669aea9c118cb2b7ad23fc6646c71.png
Restart nautilus:
nautilus -q
and you will have no thumbnail for /home/user/Pictures/image 1.png.
Now you only have to write a script that scans your particular folders and do the above steps automatically.
Credits :P
A.B.
  • 92,125
Fabby
  • 35,017
