when i try to install windows 8.1 o.s to my laptop.it shows that the required cannot be selected showing something like drive 0 cannot be installed.i my Ubuntu o.s is in u.e.f.i mode.and the entire o.s is in a single partition which is under the owner of root..i cannot unmount the drive.
Asked
Active
Viewed 115 times
I think you need to convert your hard disk from UEFI to MBR format. You can follow the below steps:
- Boot in the Windows installation using DVD or USB.
- From inside Windows Setup, press Shift+F10 to open a command prompt window or you can go to Repair your computer >> Advanced Options >> Command Prompt
- In Command Prompt, open the diskpart tool:
diskpart
- Identify the drive to reformat:
list disk
- Select the drive, and reformat it:
select disk "disk number"
clean
convert mbr
exit
Continue with your Windows 8.1 installation. Your problem should be solved by this.
Alternatively you can also convert your UEFI/GPT harddisk from ubuntu and then install Windows 8.1. Have a walk through GPT/UEFI to MBR conversion
Dhaval Simaria
- 825
