########## wireless info START ##########
Report from: 09 Mar 2015 18:16 IST +0530
Booted last: 09 Mar 2015 18:07 IST +0530
Script from: 20 Sep 2014 23:04 UTC +0000
##### release ###########################
Distributor ID: Ubuntu
Description:    Ubuntu 14.04.2 LTS
Release:    14.04
Codename:   trusty
##### kernel ############################
Linux 3.13.0-45-generic #74-Ubuntu SMP Tue Jan 13 19:36:28 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash, vt.handoff=7
##### desktop ###########################
Ubuntu
##### lspci #############################
02:00.0 Network controller [0280]: Broadcom Corporation BCM4313 802.11bgn Wireless Network Adapter [14e4:4727] (rev 01)
    Subsystem: Askey Computer Corp. Device [144f:7175]
    Kernel driver in use: bcma-pci-bridge
03:00.0 Ethernet controller [0200]: Qualcomm Atheros AR8152 v1.1 Fast Ethernet [1969:2060] (rev c1)
    Subsystem: Toshiba America Info Systems Device [1179:fd50]
    Kernel driver in use: atl1c
##### lsusb #############################
Bus 002 Device 005: ID 0930:0214 Toshiba Corp.
Bus 002 Device 003: ID 04f2:b1d6 Chicony Electronics Co., Ltd CNF9055 Toshiba Webcam
Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
##### PCMCIA card info ##################
##### rfkill ############################
0: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
1: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
##### lsmod #############################
brcmsmac              563041  0
cordic                 12574  1 brcmsmac
brcmutil               15618  1 brcmsmac
b43                   387371  0
mac80211              630669  2 b43,brcmsmac
cfg80211              484040  3 b43,brcmsmac,mac80211
ssb                    62379  1 b43
bcma                   52096  3 b43,brcmsmac
wmi                    19177  1 toshiba_acpi
##### interfaces ########################
auto lo
iface lo inet loopback
##### ifconfig ##########################
eth0      Link encap:Ethernet  HWaddr
          inet addr:10.208.17.214  Bcast:10.208.17.255  Mask:255.255.254.0
          inet6 addr: fe80::ca0a:a9ff:fec6:7da4/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:2789 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2053 errors:0 dropped:0 overruns:0 carrier:1
          collisions:0 txqueuelen:1000
          RX bytes:2627176 (2.6 MB)  TX bytes:238415 (238.4 KB)
wlan0     Link encap:Ethernet  HWaddr
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
##### iwconfig ##########################
eth0      no wireless extensions.
lo        no wireless extensions.
wlan0     IEEE 802.11bgn  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=27 dBm
          Retry  long limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
##### route #############################
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         10.208.16.1     0.0.0.0         UG    0      0        0 eth0
10.208.16.0     0.0.0.0         255.255.254.0   U     1      0        0 eth0
##### resolv.conf #######################
nameserver 127.0.0.1
search pune.cdac.in
##### nm-tool ###########################
NetworkManager Tool
State: connected (global)
- Device: eth0  [Wired connection 1] -------------------------------------------
  Type:              Wired
  Driver:            atl1c
  State:             connected
  Default:           yes
  HW Address:
  Capabilities:
    Carrier Detect:  yes
    Speed:           100 Mb/s
  Wired Properties
    Carrier:         on
  IPv4 Settings:
    Address:         10.208.17.214
    Prefix:          23 (255.255.254.0)
    Gateway:         10.208.16.1
    DNS:             10.208.0.11
    DNS:             10.208.0.12
- Device: wlan0 ----------------------------------------------------------------
  Type:              802.11 WiFi
  Driver:            brcmsmac
  State:             disconnected
  Default:           no
  HW Address:
  Capabilities:
  Wireless Properties
    WEP Encryption:  yes
    WPA Encryption:  yes
    WPA2 Encryption: yes
  Wireless Access Points
    Ldap:            Infra, , Freq 2462 MHz, Rate 54 Mb/s, Strength 37 WPA2 Enterprise
    Vayudoot-Teachers: Infra, , Freq 2462 MHz, Rate 54 Mb/s, Strength 35 WPA2 Enterprise
    SKY NET:         Infra, , Freq 2462 MHz, Rate 54 Mb/s, Strength 34 WPA2 Enterprise
    Vayudoot-Administrative: Infra, , Freq 2462 MHz, Rate 54 Mb/s, Strength 32 WPA2 Enterprise
    Vayudoot-Administrative: Infra, , Freq 2412 MHz, Rate 54 Mb/s, Strength 35 WPA2 Enterprise
    Ldap:            Infra, , Freq 2412 MHz, Rate 54 Mb/s, Strength 32 WPA2 Enterprise
    VAYUDOOT:        Infra, , Freq 2462 MHz, Rate 54 Mb/s, Strength 37 WPA2 Enterprise
    SKY NET:         Infra, , Freq 2412 MHz, Rate 54 Mb/s, Strength 35 WPA2 Enterprise
    CNC_NEW_NETWORK: Infra, , Freq 2462 MHz, Rate 54 Mb/s, Strength 39 WPA2
    CNC_NEW_NETWORK: Infra, , Freq 2412 MHz, Rate 54 Mb/s, Strength 29 WPA2
    Vayudoot-Students: Infra, , Freq 2462 MHz, Rate 54 Mb/s, Strength 37 WPA2 Enterprise
    Vayudoot-Guest:  Infra, , Freq 2412 MHz, Rate 54 Mb/s, Strength 29 WPA2 Enterprise
    Vayudoot-Guest:  Infra, , Freq 2462 MHz, Rate 54 Mb/s, Strength 37 WPA2 Enterprise
    Vayudoot-Teachers: Infra, , Freq 2412 MHz, Rate 54 Mb/s, Strength 29 WPA2 Enterprise
    Vayudoot-Students: Infra, , Freq 2412 MHz, Rate 54 Mb/s, Strength 37 WPA2 Enterprise
    VAYUDOOT:        Infra, , Freq 2412 MHz, Rate 54 Mb/s, Strength 34 WPA2 Enterprise
    Vayudoot-Administrative: Infra, , Freq 2462 MHz, Rate 54 Mb/s, Strength 22 WPA2 Enterprise
    VAYUDOOT:        Infra, , Freq 2462 MHz, Rate 54 Mb/s, Strength 20 WPA2 Enterprise
    CDAC:            Infra, , Freq 2437 MHz, Rate 54 Mb/s, Strength 35
    CNC_NEW_NETWORK: Infra, , Freq 2462 MHz, Rate 54 Mb/s, Strength 20 WPA2
    CDAC:            Infra, , Freq 2412 MHz, Rate 54 Mb/s, Strength 40
    Vayudoot-Students: Infra, , Freq 2462 MHz, Rate 54 Mb/s, Strength 20 WPA2 Enterprise
    SKY NET:         Infra, , Freq 2462 MHz, Rate 54 Mb/s, Strength 19 WPA2 Enterprise
##### NetworkManager.state ##############
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
WimaxEnabled=true
##### NetworkManager.conf ###############
[main]
plugins=ifupdown,keyfile,ofono
dns=dnsmasq
[ifupdown]
managed=false
##### NetworkManager profiles ###########
[[/etc/NetworkManager/system-connections/CDAC]] (600 root)
[connection] id=CDAC | type=802-11-wireless
[802-11-wireless] ssid=CDAC | mac-address=
[ipv6] method=auto
[ipv4] method=auto
[[/etc/NetworkManager/system-connections/CNC_NEW_NETWORK]] (600 root)
[connection] id=CNC_NEW_NETWORK | type=802-11-wireless
[802-11-wireless] ssid=CNC_NEW_NETWORK | mac-address=
[ipv4] method=auto
[ipv6] method=auto
##### iw reg get ########################
Region: Asia/Kolkata (based on set time zone)
country US:
    (2402 - 2472 @ 40), (3, 27)
    (5170 - 5250 @ 40), (3, 17)
    (5250 - 5330 @ 40), (3, 20), DFS
    (5490 - 5600 @ 40), (3, 20), DFS
    (5650 - 5710 @ 40), (3, 20), DFS
    (5735 - 5835 @ 40), (3, 30)
    (57240 - 63720 @ 2160), (N/A, 40)
##### iwlist channels ###################
eth0      no frequency information.
lo        no frequency information.
wlan0     11 channels in total; available frequencies :
          Channel 01 : 2.412 GHz
          Channel 02 : 2.417 GHz
          Channel 03 : 2.422 GHz
          Channel 04 : 2.427 GHz
          Channel 05 : 2.432 GHz
          Channel 06 : 2.437 GHz
          Channel 07 : 2.442 GHz
          Channel 08 : 2.447 GHz
          Channel 09 : 2.452 GHz
          Channel 10 : 2.457 GHz
          Channel 11 : 2.462 GHz
##### iwlist scan #######################
Channel occupancy:
      6   APs on   Frequency:2.412 GHz (Channel 1)
      1   APs on   Frequency:2.437 GHz (Channel 6)
      8   APs on   Frequency:2.462 GHz (Channel 11)
eth0      Interface doesn't support scanning.
lo        Interface doesn't support scanning.
wlan0     Scan completed :
          Cell 01 - Address:
                    Channel:6
                    Quality=32/70  Signal level=-78 dBm
                    Encryption key:off
                    ESSID:"CDAC"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s
                              24 Mb/s; 36 Mb/s; 54 Mb/s
                    Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 48 Mb/s
                    Mode:Master
                    Extra:tsf=000001acf35873af
                    Extra: Last beacon: 32ms ago
          Cell 02 - Address:
                    Channel:1
                    Quality=41/70  Signal level=-69 dBm
                    Encryption key:off
                    ESSID:"CDAC"
                    Mode:Master
                    Extra:tsf=000000e3f2bf2c2c
          Cell 03 - Address:
                    Channel:1
                    Quality=28/70  Signal level=-82 dBm
                    Encryption key:on
                    ESSID:"SKY NET"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 6 Mb/s; 9 Mb/s
                              11 Mb/s; 12 Mb/s; 18 Mb/s
                    Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
                    Mode:Master
                    Extra:tsf=00000014f9481178
                    Extra: Last beacon: 624ms ago
                    IE: IEEE 802.11i/WPA2 Version 1
                        Group Cipher : CCMP
                        Pairwise Ciphers (1) : CCMP
                        Authentication Suites (1) : 802.1x
                       Preauthentication Supported
          Cell 04 - Address:
                    Channel:1
                    Encryption key:on
                    ESSID:"VAYUDOOT"
                    Mode:Master
                    Extra:tsf=00000014f949a977
                    Extra: Last beacon: 592ms ago
                        Group Cipher : CCMP
          Cell 05 - Address:
                    Channel:11
                    Encryption key:on
                    ESSID:"Vayudoot-Administrative"
                    Mode:Master
                    Extra:tsf=0000002a1f9ae978
                    Extra: Last beacon: 156ms ago
                        Group Cipher : CCMP
          Cell 06 - Address:
                    Channel:11
                    Encryption key:on
                    ESSID:"CNC_NEW_NETWORK"
                    Mode:Master
                    Extra:tsf=0000002a1f9c8bc8
                    Extra: Last beacon: 36ms ago
                        Group Cipher : CCMP
                        Authentication Suites (1) : PSK
          Cell 07 - Address:
                    Channel:11
                    Quality=34/70  Signal level=-76 dBm
                    Encryption key:on
                    ESSID:"SKY NET"
                    Mode:Master
                    Extra: Last beacon: 120ms ago
                        Group Cipher : CCMP
          Cell 08 - Address:
                    Channel:1
                    Encryption key:on
                    ESSID:"Vayudoot-Teachers"
                    Mode:Master
                    Extra: Last beacon: 612ms ago
                        Group Cipher : CCMP
          Cell 09 - Address:
                    Channel:1
                    Quality=29/70  Signal level=-81 dBm
                    Encryption key:on
                    ESSID:"Vayudoot-Students"
                    Mode:Master
                    Extra: Last beacon: 580ms ago
                        Group Cipher : CCMP
          Cell 10 - Address:
                    Channel:1
                    Encryption key:on
                    ESSID:"Ldap"
                    Mode:Master
                    Extra: Last beacon: 568ms ago
                        Group Cipher : CCMP
          Cell 11 - Address:
                    Channel:11
                    Encryption key:on
                    Mode:Master
                    Extra:tsf=0000002a1f9ae977
                    Extra: Last beacon: 76ms ago
                        Group Cipher : CCMP
          Cell 12 - Address:
                    Channel:11
                    Quality=36/70  Signal level=-74 dBm
                    Encryption key:on
                    ESSID:"Ldap"
                    Mode:Master
                    Extra:tsf=0000002a1f9ce0d9
                        Group Cipher : CCMP
          Cell 13 - Address:
                    Channel:11
                    Quality=31/70  Signal level=-79 dBm
                    Encryption key:on
                    Mode:Master
                    Extra: Last beacon: 108ms ago
                        Group Cipher : CCMP
          Cell 14 - Address:
                    Channel:11
                    Quality=21/70  Signal level=-89 dBm
                    Encryption key:on
                    Mode:Master
                    Extra:tsf=00000014f9be01e6
                    Extra: Last beacon: 68ms ago
                        Group Cipher : CCMP
          Cell 15 - Address:
                    Channel:11
                    Encryption key:on
                    ESSID:"VAYUDOOT"
                    Mode:Master
                    Extra:tsf=0000002a1f9b848c
                        Group Cipher : CCMP
##### module infos ######################
[brcmsmac]
filename:       /lib/modules/3.13.0-45-generic/kernel/drivers/net/wireless/brcm80211/brcmsmac/brcmsmac.ko
firmware:       brcm/bcm43xx_hdr-0.fw
firmware:       brcm/bcm43xx-0.fw
license:        Dual BSD/GPL
description:    Broadcom 802.11n wireless LAN driver.
author:         Broadcom Corporation
srcversion:     8A64A0EA2502AA6E237B856
depends:        bcma,mac80211,brcmutil,cfg80211,cordic
intree:         Y
vermagic:       3.13.0-45-generic SMP mod_unload modversions
signer:         Magrathea: Glacier signing key
sig_key:        34:99:21:39:F3:DA:40:B6:20:BD:55:17:59:7B:A8:5A:F5:79:7C:9A
sig_hashalgo:   sha512
[brcmutil]
filename:       /lib/modules/3.13.0-45-generic/kernel/drivers/net/wireless/brcm80211/brcmutil/brcmutil.ko
description:    Broadcom 802.11n wireless LAN driver utilities.
srcversion:     E81EE4CBB6A7A689150D93D
depends:
intree:         Y
[b43]
filename:       /lib/modules/3.13.0-45-generic/kernel/drivers/net/wireless/b43/b43.ko
firmware:       b43/ucode9.fw
firmware:       b43/ucode5.fw
firmware:       b43/ucode16_mimo.fw
firmware:       b43/ucode15.fw
firmware:       b43/ucode14.fw
firmware:       b43/ucode13.fw
firmware:       b43/ucode11.fw
license:        GPL
author:         Rafał Miłecki
author:         Gábor Stefanik
author:         Michael Buesch
author:         Stefano Brivio
author:         Martin Langer
description:    Broadcom B43 wireless driver
srcversion:     7ABBDDCA84C087640B27AE6
depends:        bcma,ssb,mac80211,cfg80211
intree:         Y
parm:           bad_frames_preempt:enable(1) / disable(0) Bad Frames Preemption (int)
parm:           fwpostfix:Postfix for the .fw files to load. (string)
parm:           hwpctl:Enable hardware-side power control (default off) (int)
parm:           nohwcrypt:Disable hardware encryption. (int)
parm:           hwtkip:Enable hardware tkip. (int)
parm:           qos:Enable QOS support (default on) (int)
parm:           btcoex:Enable Bluetooth coexistence (default on) (int)
parm:           verbose:Log message verbosity: 0=error, 1=warn, 2=info(default), 3=debug (int)
parm:           pio:Use PIO accesses by default: 0=DMA, 1=PIO (int)
parm:           allhwsupport:Enable support for all hardware (even it if overlaps with the brcmsmac driver) (int)
[mac80211]
filename:       /lib/modules/3.13.0-45-generic/kernel/net/mac80211/mac80211.ko
license:        GPL
description:    IEEE 802.11 subsystem
srcversion:     385697223F8285F67C93A06
depends:        cfg80211
intree:         Y
parm:           max_nullfunc_tries:Maximum nullfunc tx tries before disconnecting (reason 4). (int)
parm:           max_probe_tries:Maximum probe tries before disconnecting (reason 4). (int)
parm:           beacon_loss_count:Number of beacon intervals before we decide beacon was lost. (int)
parm:           probe_wait_ms:Maximum time(ms) to wait for probe response before disconnecting (reason 4). (int)
parm:           ieee80211_default_rc_algo:Default rate control algorithm for mac80211 to use (charp)
[cfg80211]
filename:       /lib/modules/3.13.0-45-generic/kernel/net/wireless/cfg80211.ko
description:    wireless configuration support
license:        GPL
author:         Johannes Berg
srcversion:     C2478077E22138832B71659
depends:
intree:         Y
parm:           ieee80211_regdom:IEEE 802.11 regulatory domain code (charp)
parm:           cfg80211_disable_40mhz_24ghz:Disable 40MHz support in the 2.4GHz band (bool)
[ssb]
filename:       /lib/modules/3.13.0-45-generic/kernel/drivers/ssb/ssb.ko
license:        GPL
description:    Sonics Silicon Backplane driver
srcversion:     3DE188310F77C566C2E8CB3
depends:
intree:         Y
[bcma]
filename:       /lib/modules/3.13.0-45-generic/kernel/drivers/bcma/bcma.ko
license:        GPL
description:    Broadcom's specific AMBA driver
srcversion:     E41B811D88783DD5BC38565
depends:
intree:         Y
##### module parameters #################
[b43]
allhwsupport: 0
bad_frames_preempt: 0
btcoex: 1
hwpctl: 0
hwtkip: 0
nohwcrypt: 0
pio: 0
qos: 1
verbose: 2
[mac80211]
beacon_loss_count: 7
ieee80211_default_rc_algo: minstrel_ht
max_nullfunc_tries: 2
max_probe_tries: 5
probe_wait_ms: 500
[cfg80211]
cfg80211_disable_40mhz_24ghz: N
ieee80211_regdom: 00
##### /etc/modules ######################
lp
rtc
b43
##### modprobe options ##################
[/etc/modprobe.d/blacklist-ath_pci.conf]
blacklist ath_pci
[/etc/modprobe.d/blacklist.conf]
blacklist evbug
blacklist usbmouse
blacklist usbkbd
blacklist eepro100
blacklist de4x5
blacklist eth1394
blacklist snd_intel8x0m
blacklist snd_aw2
blacklist i2c_i801
blacklist prism54
blacklist bcm43xx
blacklist garmin_gps
blacklist asus_acpi
blacklist snd_pcsp
blacklist pcspkr
blacklist amd76x_edac
[/etc/modprobe.d/blacklist-rare-network.conf]
alias net-pf-3 off
alias net-pf-6 off
alias net-pf-9 off
alias net-pf-11 off
alias net-pf-12 off
alias net-pf-19 off
alias net-pf-21 off
alias net-pf-36 off
[/etc/modprobe.d/iwlwifi.conf]
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
[/etc/modprobe.d/mlx4.conf]
softdep mlx4_core post: mlx4_en
##### rc.local ##########################
exit 0
##### pm-utils ##########################
##### udev rules ########################
[/etc/udev/rules.d/70-persistent-net.rules]
# PCI device 0x1969:0x2060 (atl1c)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0"
# PCI device 0x14e4:0x4727 (brcmsmac)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="wlan*", NAME="wlan0"
##### dmesg #############################
[   19.210007] brcmsmac bcma0:0: brcms_ops_bss_info_changed: qos enabled: false (implement)
[   19.210061] brcmsmac bcma0:0: brcms_ops_config: change power-save mode: false (implement)
[   19.210251] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready (repeated 2 times)
[   50.709566] wlan0: authenticate with
[   50.712465] wlan0: send auth to  (try 1/3)
########## wireless info END ############
Wild Man
  • 8,327
Hitesh
Do:
echo "blacklist b43" | sudo tee -a /etc/modprobe.d/blacklist.conf
echo "blacklist ssb" | sudo tee -a /etc/modprobe.d/blacklist.conf
Reboot and wifi should be working.
Wild Man
  • 8,327
