WIFI still does not work, I tried several options. Is there something that will work 100%? I expected that linux will be easier!
I have LUBUNTU 14.10.
First I tried:
sudo apt-get remove --purge bcmwl-kernel-source
sudo apt-get install linux-firmware-nonfree
And ... does not work.
Then I found the discussion to another command. For this to me disappeared and LAN, so that I was completely cut off from the internet and I had to reinstall the whole Lubuntu again :(
linux-headers-generic
On the contrary, the third time I found a script that ZEPRO works. And ... does not work.
sudo apt-get install firmware-b43-installer b43-fwcutter
I tried to insert the * .inf driver of WIN7 for my wifi card via WINE - Ndiswrapper. Hardware not found, but the configuration - adding wifi, again nothing.
WIFI is working and even finds SSID, but when I enter the correct WPA password, it does not connect WIFI. I also tried to reset the password of the WIFI router , but the notebook does not connect via WIFI.
bummi
  • 394
First of all, ndiswrapper is not required. Let's remove it:
sudo apt-get purge ndiswrapper-common
sudo rm -rf /etc/ndiswrapper
Make sure that the needed driver is loaded:
lsmod | grep b43
If not, let's load it:
sudo modprobe b43
If it didn't load automatically, it is probably blacklisted somewhere; check:
ls /etc/modprobe.d
Once you post the result, we'll find and remove the blacklist.
Finally, be certain the wireless switch or key combination is set to enable wireless:
rfkill list all
chili555
  • 61,330
