When i try to install 'youtube to mp3' in the software center
I get the following error:
the following packages have unmet dependencies:
youtube-to-mp3: Depends: libc6 (>= 2.14) but 2.19-0ubuntu6.6 is to be installed
                Depends: libgcc1 (>= 1:4.1.1) but 1:4.9.1-0ubuntu1 is to be installed
                Depends: libqt4-declarative (>= 4:4.7.0~rc1) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4 is to be installed
                Depends: libqt4-network (>= 4:4.6.1) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4 is to be installed
                Depends: libqtcore4 (>= 4:4.8.0) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4 is to be installed
                Depends: libqtgui4 (>= 4:4.8.0) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4 is to be installed
                Depends: libstdc++6 (>= 4.6) but 4.8.2-19ubuntu1 is to be installed
                Depends: libav-tools (>= 4:0.8.6-0ubuntu0.12.04.1) but 6:9.16-0ubuntu0.14.04.1 is to be installed
                Depends: libavcodec-extra-53 (>= 4:0.8.6ubuntu0.12.04.1) but it is not going to be installed
                Depends: libmp3lame0 (>= 3.99.3+repack1-1) but 3.99.5+repack1-3ubuntu1 is to be installed
when I run it in the terminal:
sudo apt-get install youtube-to-mp3
I get the folowing message:
   youtube-to-mp3 : Depends: libavcodec-extra-53 (>=4:0.8.6ubuntu0.12.04.1) but it is not installable
Well, I've got an alternative if you change your mind
sudo apt-get install youtube-dl
Using this you can download mp3 , video of your choice using -F to find the number format and -f number to download eg :
youtube-dl -f 18 https://www.youtube.com/watch?v=anything
Mayur Kulkarni
  • 550
  • 14
The best way to get it installed is given in the link or follow the steps.
sudo add-apt-repository http://www.mediahuman.com/packages/ubuntu
sudo apt-key adv --keyserver pgp.mit.edu --recv-keys D808832C7D19F1F3
sudo apt-get update
Everything should go well and you would be having youtube-to-mp3 installed on your Ubuntu 14.04.
Please refer to Are PPA's safe to add to my system and what are some “red flags” to watch out for? for the potential dangers of using PPAs.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
