I encrypted my swap with ecryptfs, but sometimes when I boot during the splash screen it says the swap is not encrypted, then it disappears. How can I check if it is encrypted?
Only my $HOME files are encrypted. What can be done about the information that leaks into system directories like /var/log? To where does it leak? How can I clean them systematically?
Supposing the answer to number 2 is that it leaks a lot, is full HD encryption a better option to solve this? If yes, what free program to use, since ecryptfs does not have this option?
- 18,589
- 12,304
You should really ask one question at a time, instead of 3 together.
You can see your swap partitions with:
cat /proc/swaps
And you can see your device-mapper encrypted swap partition configuration with:
cat /etc/crypttab
As long as all of your swap partitions listed in /proc/swaps are also configured for encryption in /etc/crypttab, you're in good shape.
Home Directory Encryption is only meant to protect the data you store in your home directory, and is intended as a balance among security, usability, and performance. Various bits of system information "leak" (as you say) to /etc (configuration files), /var (varying program information and log files) and /tmp (temporary files). If you want to encrypt all of that, you should use full disk encryption, which you can configure at installation using the Ubuntu Alternate Install media.
- 14,919
