My netbook's xp os doesn't work so i want to install lubuntu but what i have to do? Download the llubuntus latest version and then my netbook's drivers and that's it? Help
Netbook (Acer a0531h) Thanks
You will need to download your preferred version of Lubuntu (I recommend the LTS version) and then create a boot usb with the downloaded image file.
Once you have created the boot usb insert it into your laptop and boot it up. Different laptops use different keybindings but look for a setting that says something like "select boot device" and press (and hold) the corresponding key during the boot-up process. If you don't see any text like that it will likely be f10, f11, f12 or escape, try each of these.
From there the Lubuntu installer will start and you should be able to follow the on-screen instructions from there.
