I installed the packages zsh and zsh-doc, but when I type man zsh, I get no manual entry for zsh. Where can I find zsh docs?
Asked
Active
Viewed 881 times
You can find the docs in /usr/share/doc/zsh-common. I suspect if you also install zsh-common, you will also find the man pages.
ZSH(1) General Commands Manual ZSH(1)
NAME
zsh - the Z shell
OVERVIEW
Because zsh contains many features, the zsh manual has been split into
a number of sections:
zsh Zsh overview (this section)
zshroadmap Informal introduction to the manual
zshmisc Anything not fitting into the other sections
<snip>
It appears to be a bug: https://bugs.launchpad.net/ubuntu/+source/zsh/+bug/1242108 Posts #21 and 22 suggest work-arounds. It is apparently fixed for Ubuntu 14.10 as it works perfectly on my system.
chili555
- 61,330
