I downloaded two .iso files, but couldn't open them with Ark. So I installed 7zip using wine (software called wine, not actual alcohol) and was able to open and extract one of them, but I'm still unable to open or extract other one.
Also, assuming the iso files are damaged, is there way (or software) to open them?
Any suggestions?
Note: I use Kubuntu.
Edit: Using:
sudo -i
mount -o loop /home/ftl/Downloads/folder/file.iso /mnt
results in:
   mount: wrong fs type, bad option, bad superblock on /dev/loop0,
   missing codepage or helper program, or other error
   In some cases useful info is found in syslog - try
   dmesg | tail or so.
Carolus
  • 600
Sounds as if the iso are corrupt. Otherwise you can loop mount them.
sudo -i
mount -o loop your.iso /mnt
The files are then available under /mnt. Post any error messages you get.
If you want a graphical interface use gisomount
See https://help.ubuntu.com/community/MountIso for additional information.
Panther
  • 104,528
It seems it may be broken. You may mount it using this commands on terminal:
sudo mkdir -p /mnt/disk
sudo mount -o loop DISKNAME.iso /mnt/disk
This way it should be mounted to /mnt/disk It always worked to me, if not, the image should be damaged
