i installed glib2.42 from source but that's creating a problem for me. So i tried to downgrade it running make uninstall and installed glib2.28 afterwards. But now when i try to build a software using glib a dependency, it shows this error:
*** 'pkg-config --modversion glib-2.0' returned 2.28.8, but GLIB (2.42.1)
*** was found! If pkg-config was correct, then it is best
*** to remove the old version of GLib. You may also be able to fix the error
*** by modifying your LD_LIBRARY_PATH enviroment variable, or by editing
*** /etc/ld.so.conf. Make sure you have run ldconfig if that is
*** required on your system.
*** If pkg-config was wrong, set the environment variable PKG_CONFIG_PATH
*** to point to the correct configuration files
no
configure: error: Cannot find GLIB: Is pkg-config in your path?
How can i resolve this and keep gib2.28?
