-1
my wifi connection is very slowly and inestable, i install dual boot on my machine in windows 8.1 wifi is ok, but in ubuntu kernel 3.16 after some minutes is each time more slowly, my card information (sudo lshw -C network) is
  *-network
       description: Wireless interface
       product: BCM43142 802.11b/g/n
       vendor: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:01:00.0
       logical name: wlan0
       version: 01
       serial: 38:b1:db:fd:6b:1b
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=wl0 driverversion=6.30.223.248 (r487574) ip=192.168.0.14 latency=0 multicast=yes wireless=IEEE 802.11abg
       resources: irq:16 memory:b2500000-b2507fff
  *-network
       description: Ethernet interface
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: eth0
       version: 10
       serial: d0:bf:9c:88:76:2f
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168g-3_0.0.1 04/23/13 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       resources: irq:44 ioport:4000(size=256) memory:b2404000-b2404fff memory:b2400000-b2403fff
Sparhawk
  • 6,969
Are you sure it is not an update or something else that is starting to run (like normally in Windows...) Check processor activity with System Monitor and test network speed (with a known speed test site) to confirm. Disconnect and reconnect and do speed test again to make sure it is a driver or configuration issue. Sorry, this is all I can help.
