Today I did a scan of my machine with rkhunter:
sudo rkhunter --checkall
And these were the warnings that I got:
Checking for passwd file changes                         [ Warning ]
Checking for group file changes                          [ Warning ]
Is this anything to worry about? And if it is then how should I proceed?
OS Information:
Description:    Ubuntu 14.10
Release:    14.10
You need to ask yourself:
  • did I add a user?
  • did I install software that might have added a user?
Best method to use is to list the /etc/passwd file on your screen with
more /etc/passwd
and to check for unexpected usernames.
These notices from rkhunter are more than likely caused by an out of date reference file. You might want to do a ...
sudo rkhunter --update
sudo rkhunter --propupd
after you install new software. The 1st creates a new database reference file and the 2nd marks that reference file as a starting point.
If a rootkit is found it is likely to throw more alarms than just a notice regarding /etc/passwd. That is just a file holding your "users" and it is not enough to start a rootkit.
Rinzwind
  • 309,379
