Recently I have switched my OS from Windows to Ubuntu 14.04, but I need Adobe Photoshop to run for my project. So how can I run Adobe Photoshop on Ubuntu, or are there any Ubuntu plugin like photo editor software?
I'm an Ubuntu user caught in a similar situation with Adobe Creative Cloud [at school]. So if you must use Photoshop in Ubuntu ... then there's 2 options:
a.) Run Photoshop under Wine-HQ;
- Only certain versions of Photoshop and Wine-HQ work.
b.) Use virtualization to run Photoshop in a Windows guest operating system.
I chose virtualization. But found that there's drawbacks if you don't have the right hardware, or pick the right virtualization program to run a guest OS.
This is because Photoshop needs 3D acceleration and plenty of VRAM to work like it's suppose to, and not complain via pop-up warning .... So if you're on a production system, mapping out a game plan is a priority, to avoid tears later.
From what I've come to understand, the best results for Photoshop with virtualization needs:
- It's standard system requirements.
- CPU with Vt-d or AMD-virtualization(TM); and IOMMU
- Enable Virtualization and IOMMU in Bios/UEFI
- 2 Graphics cards (1 is dedicated to the Guest OS. For instance, use onboard or integrated graphics for host, and GPU for virtualization).
- And of course ... you gotta have power to run both the host (Ubuntu), and Windows guest (Win can be CPU hog when the guest is first turned on).
NOTE: I can use Photoshop CC 2014 with only 1 Graphics card, and 256MB of VRAM in Virtualbox. But it prevents me from using 3D effects, etc.
PS: I just read a post about Pixeluvo being a strong competitor to Photoshop (by an alleged "pro"). It's an inexpensive commercial app, with a native program for Ubuntu (see: http://www.pixeluvo.com).
- 11
- 1
There is a vector image draw tool in Ubuntu called inkscape. Follow these steps to install inkscape.
Open terminal(Crtl+Alt+T) and execute following commands one by one
sudo add-apt-repository ppa:inkscape.dev/stable
sudo apt-get update
sudo apt-get install inkscape
There is another photo editor software (easier to use than inkscape) called gimp. Follow these steps to install gimp
sudo add-apt-repository ppa:otto-kesselgulasch/gimp
sudo apt-get update
sudo apt-get install gimp
- 4,569
- 1
- 25
- 31
It's supposed to work on WINE but I tried installing it on CS6 and failed miserably on every try. However there is a much easier way:
sudo apt-get install playonlinux
It's got an installation script for Photoshop CS6 (works like a charm!), here it is: https://www.playonlinux.com/pl/app-2316-Adobe_Photoshop_CS6.html
There's also a script for Illustrator CS6. Supposedly those scripts might work with CC versions, but I haven't tested that. If you need the latest CC you can always use VirtualBox.
- 269
- 1,164
- 2
- 11
- 19
