I have Ubuntu 14.04.2 installed on Lenovo Flex 2 laptop. My problem is that whenever I select shutdown from the menu, the laptop restarts instead of completely shutting down. Any idea why this might be happening?
The shutdown from the UI rarely works for me. It has been very iffy in versions for the last 4 years.
Someone might be able to place insight on directly why. But for a resolution you can install cairo-dock and use that UI shutdown problem free.
You can install it with:
$ sudo apt-get install cairo-dock
Now run it from the Launch button. Use this alternate shutdown option. It'll work every time.
I didn't include this in my original answer because it appeared that you were trying to use the GUI.
This will also work every time:
$ sudo shutdown -h now
You can also reboot the computer by issuing:
$ sudo shutdown -r now
Check other cli shutdown options with:
$ man shutdown
Of course you can put this in a script and create a myshutdown.desktop icon to execute the shutdown script with a click.
- 25,444
You may create script for shutdown by executing following commands :
sudo gedit shutdown_system
and write sudo poweroff in the file and save it.
then change permission by chmod +x shutdown_system
Execute the file for shutting down the system.
./shutdown_system
Hope it helps!
- 4,569
- 1
- 25
- 31
