i want startup a programm in a specific desktop with a .desktop config file
for example firefox on desktop 2
For tasks like this I always suggest devilspie2:
http://www.gusnan.se/devilspie2/
is a window matching utility, allowing the user to perform scripted actions on windows as they are created. For example you can script a terminal program to always be positioned at a specific screen position, or position a window on a specific workspace.
Add .desktop files to /home/username/.config/autostart and make sure they're marked as executables.
Here is a default syntax for a .desktop file with some of the most important entries.
[Desktop Entry]
Type=Application
Encoding=UTF-8
Name="NAME OF THE APPLICATION"
Comment="WHAT DOES THE APP DO?"
Exec="EXECUTABLE PATH OF APPLICATION"
Hidden=false
NoDisplay=false
Terminal=false
For example :
To Autostart firefox, execute the following commands in terminal :
gedit ~/.config/autostart/firefox.desktop
and copy the following content in the file (firefox.desktop) and then save it
[Desktop Entry]
Type=Application
Encoding=UTF-8
Name=Firefox
Comment=Firefox Web Browser
Exec=firefox
Hidden=false
NoDisplay=false
Terminal=false
then mark it as executable by executing following command in terminal :
chmod +x ~/.config/autostart/firefox.desktop
Similarly you can autostart other applications. For applications that have their binaries in /usr/bin , full path isn't required (like firefox)
Logout and login again to see the changes!
