I downloaded packet tracer which was a zip file, and after extracting it, i am not sure how to run it since when i open the folder there aren't any icons (I have been used to windows) and to make me a little more lost, upon opening the folder it has an "install script". I added the liberty of sharing this through Google drive so you can replicate and better understand my problem. Use VM wear with it or just click the download arrow at https://drive.google.com/file/d/0BwNyCfESFvvUMWJoVVB1Qm9nSkk/view
Thanks for your time.!
Asked
Active
Viewed 3,839 times
LinUbuser
- 21
Unzip the file into a local directory. Open a terminal (Ctrl + Alt + T) and cd to the directory. Find the install script and enter chmod +x install followed by sudo ./install. That should work.
A little explanation: The chmod makes your script executable (which it isn't by default, for security reasons). The install script itself should be run with sudo because ordinary users can not modify system directories.
Jos
- 30,529
- 8
- 89
- 96
