I have run:
sudo apt-get upgrade && sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get autoremove
sudo apt-get autoclean
but same :(
Here's log:
 wine1.7 : Depends: wine1.7-i386 (= 1:1.7.34-0ubuntu1~ppa1)
        Recommends: gnome-exe-thumbnailer but it is not going to be installed or
 kde-runtime but it is not going to be installed
JoKeR
  • 7,062
Nhóc Emi
  • 2,871
Execute these commands one by one in Terminal (Crtl+Alt+T) :
sudo apt-get install -f
sudo apt-get update
Faizan Akram Dar
  • 4,569
  • 25
  • 31
Have you tried enter this in the terminal, and use a older wine first try this:
      sudo add-apt-repository ppa:ubuntu-wine
      sudo apt-get update
      sudo apt-get install wine1.4 winetricks
and then install a newer one enter this:
      sudo apt-get install wine1.7
and this might fix the issue on this one.
Michael
  • 2,597
