I was trying to follow instructions provided in this question AFAIU bcmwl-kernel-source is a proper driver for me. But after installation nothing changed. By "nothing changed" I mean iwconfig shows only eth0 and l0 with no wireless extensions, rfkill list all contains hci0: Bluetooth.
I found that bcm43xx was blacklisted in /etc/modprobe.d/blacklist.conf, after commenting this line and removing previously installed driver I repeated the same actions. The result was the same.
The line above the bcm43xx in /etc/modprobe.d/blacklist.conf file says "replaced by b43 and ssb". So I have removed previously installed driver again and edited back blacklist.conf.
I installed firmware-b43-installer, b43 was listed in the lsmod, but I am still was not be able to see any wlan in iwconfig.
Any help will be highly appreciated.
edit1
lspci -vnn | grep Network
06:00.0 Network controller [0280]: Broadcom Corporation BCM4360 802.11ac Wireless Network Adapter [14e4:43a0] (rev 03)
edit2
sudo apt-get install --reinstall bcmwl-kernel-source
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 0 B/1,126 kB of archives.
After this operation, 0 B of additional disk space will be used.
(Reading database ... 225024 files and directories currently installed.)
Preparing to unpack .../bcmwl-kernel-source_6.30.223.141+bdcom-0ubuntu2_amd64.deb ...
Removing all DKMS Modules
Done.
Unpacking bcmwl-kernel-source (6.30.223.141+bdcom-0ubuntu2) over (6.30.223.141+bdcom-0ubuntu2) ...
Setting up bcmwl-kernel-source (6.30.223.141+bdcom-0ubuntu2) ...
Loading new bcmwl-6.30.223.141+bdcom DKMS files...
Building only for 3.16.0-31-generic
Building for architecture x86_64
Building initial module for 3.16.0-31-generic
Error! Bad return status for module build on kernel: 3.16.0-31-generic (x86_64)
Consult /var/lib/dkms/bcmwl/6.30.223.141+bdcom/build/make.log for more information.
modprobe: FATAL: Module wl not found.
update-initramfs: deferring update (trigger activated)
Processing triggers for initramfs-tools (0.103ubuntu4.2) ...
update-initramfs: Generating /boot/initrd.img-3.16.0-31-generic
sudo modprobe wl
