I installed windows8.1 on my new laptop after that i installed ubuntu12.04 as dual OS . now i am able to use only ubuntu, windows is not booting. how can i get my windows back to use as dual OS. Both the OS installations are in legacy mode
Asked
Active
Viewed 65 times
Follow these steps from Ubuntu :
Open terminal by pressing Ctrl+Alt+T Or Search
Terminalin Dash.Enter the following command in Terminal :
sudo gedit /etc/default/grub(This will open grub configuration file in
gedit.)Edit the file and change following options as following (remove comments # before any of below lines) and save the file :
GRUB_DEFAULT=0
GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=false
GRUB_TIMEOUT=10Run the following command in new instance of terminal :
sudo update-grubRestart your computer, you should be now able to boot Windows if you did partition your system correct
Mudit Kapil
- 2,081
Faizan Akram Dar
- 4,569
- 1
- 25
- 31
