im a linux beginner and used google & Co. by installing the requirements ( http://doc.qt.io/qt-5/linux.html ) for Qt:
sudo apt-get install build-essential libgl1-mesa-dev
i get the following error:
 libcheese-gtk23 : Depends: libclutter-gtk-1.0-0 (>= 0.91.8) but it is not going to be installed
                   Depends: libcogl15 (>= 1.15.8) but it is not going to be installed
 libcheese7 : Depends: libclutter-gst-2.0-0 (>= 0.10.0) but it is not going to be installed
              Depends: gstreamer1.0-clutter but it is not going to be installed
 libclutter-1.0-0 : Depends: libcogl-pango15 (>= 1.15.8) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
i solved the problem by removing libcheese-gtk23, libcheese7 and libclutter-1.0-0, but killed my Linux with this (i could install and use Qt, but after rebooting, the gui was dead).
if i dont install build-essential and libgl1-mesa-dev the Qt tells me, "cannot find -lGL".
My system: Zenbook 303LN, i7-4500u with HD4000, NVIDIA Gforce 840M, 256GB SSD, 8GB RAM, 64bit Ubuntu 14.04
Thanks for help
mdede
Clutter is required to run the new GTK 3 desktop environments. Reinstall those libraries, and try running sudo apt-get dist-upgrade to force everything to upgrade, which will likely allow you to then install libgl without any further problems.
aborsim
  • 351
