Sometimes it's important to keep current versions of already installed packages when upgrading Ubuntu release, let's say, from 12.04 to 14.04.
I don't emphasize if it's server or desktop assuming this procedure should be same.
Standard release upgrade steps are:
  1. sudo apt-get update
  2. sudo do-release-upgrade
But this will upgrade packages as well. Is there a way to keep versions of already installed packages?
UPDATE 1:
  • I will perform release upgrades remotely, so I will a need command line solution. It's possible to check versions using dpkg, apt-cache policy (and maybe with aptitude, haven't tried yet).
  • I won't have any packages in remote computer's repository. I will just need to specify what versions I need and it will download that required packages.
I feel like I will need to write a custom script to solve this issue, but it doesn't seem the best way - packages will be upgrading along with a release upgrade and then I will downgrade them. It'd be nice if I were able to install/keep required version during a release upgrade process.
Askar
  • 167
you would be best downloading the packages and saving them to a USB or CD/DVD Rom for install at a later date.
