i have bought a new Dell inspiron 15 - 3542 that has Nvidia (GM108M [GeForce 840M]). every time i install the Nvidia driver i have a black screen at the next boot, so i need to format again ! which causes me a huge pain ! this is what i get from (sudo lshw -C video)
 *-display
   description: VGA compatible controller
   product: Haswell-ULT Integrated Graphics Controller
   vendor: Intel Corporation
   physical id: 2
   bus info: pci@0000:00:02.0
   version: 0b
   width: 64 bits
   clock: 33MHz
   capabilities: msi pm vga_controller bus_master cap_list rom
   configuration: driver=i915 latency=0
   resources: irq:60 memory:f7400000-f77fffff memory:d0000000-dfffffff     ioport:f000(size=64)
*-display UNCLAIMED
       description: 3D controller
       product: GM108M [GeForce 840M]
       vendor: NVIDIA Corporation
       physical id: 0
       bus info: pci@0000:08:00.0
       version: a2
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress cap_list
       configuration: latency=0
       resources: memory:f6000000-f6ffffff memory:e0000000-efffffff memory:f0000000-f1ffffff ioport:d000(size=128) memory:f7000000-f707ffff
And this is what i get when i run lspci | egrep 'VGA|3D'
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 0b)
08:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 840M] (rev a2)
Any idea how to get this Nvidia card work without getting the black screen again? Please help me this is urgent !! i appreciate it !
6 Answers6
I was having the same problem, this worked for me after a lot of struggle and research, restart ubuntu and at login screen press ctrl+alt+F1 and login using your account this will take you to a terminal First, remove all the nvidia packages by:
sudo apt-get purge nvidia-*
sudo reboot
Again press ctrl+alt+F1 at login screen Then, Install nvidia packages by:
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt-get update
sudo ubuntu-drivers autoinstall
sudo reboot
Next, time you boot you will get a black screen instead of login most probably if not you are done. If you get a black screen, press ctrl+alt+F1 again and do the following:
cd /etc/X11
check whether there's a file of xorg.conf by:
ls | grep xorg.conf
It should be xorg.conf and not xorg.conf.* If not present do the following:
sudo nvidia-xconfig
Now edit the file as follows:
sudo nano xorg.conf
Under the Section Device, Identifier intel change Driver from "intel" to "modesetting" i.e: from
Driver "intel"
to
Driver "modesetting"
Now save the file and exit nano and do the following.
sudo chattr +i xorg.conf
sudo reboot
I hope this solves your problem, if there are any queries let my know. Thank You!
These links helped in the answers:
  1. Idea of changing driver to modesetting from intel
2.Modern way to install nvidia drivers
You have a system that likely uses the Intel hd graphics most the time to save power. This uses nvidia-prime to switch using Optimus technology. For some reason nvidia-prime would cause me problems as well, leaving me with a black screen every time unless I switch to Intel mode (when your screen is back press ctrl-alt-F1, log in, then key in:
sudo prime-select Intel
sudo service lightdm stop
sudo service lightdm start
At this point you should at least have your desktop back. What I suggest you do is install NVIDIA drivers but not nvidia-prime, or remove nvidia-prime, and install Bumblebee. This may work better for switching you graphics.
cP4n
  • 285
Give this a shot:
First purge the drivers you have in there with:
sudo apt-get purge nvidia*
Then add the ppa for Bumblebee:
sudo add-apt-repository ppa:bumblebee/stable
sudo apt-get update
Then install Bumblebee and Nvidia:
sudo apt-get install bumblebee bumblebee-nvidia primus nvidia-346
And potentially remove prime because I read it doesn't work with Bumblebee:
sudo apt-get purge nvidia-prime
Then reboot and cross your fingers. Hopefully this works. I personally was working on these drivers for a week with my GeForce 860M trying to get it to work right.
EDIT: Use nvidia-340 if those are the drivers that the nvidia website said you should use with your card. I just used 346 because they are the latest and compatible with the 860M
cP4n
  • 285
Certain Nvidia drivers do not work very well with certain GPU's, you have to use trial and error with apt-get to find ones that work well, this was the case for me when I had this exact problem. The one I found to work for my GTX745 was nvidia-331-update-dev, nvidia-331-update also worked, but nvidia-current and nvidia-current-update did not work for me at all, neither did most of the others.
If none of them work, go here: http://www.nvidia.com/Download/index.aspx?lang=en-us Input your computers info and it'll tell you what driver to get. Download it then follow these steps:
  1. Enter your tty command line (can be done by using ctrl+alt+f1, to go back, ctrl+alt+f7) Side note, if you're using a laptop, you might need to also use the fn key.
  2. In the command line, login, it will prompt you enter a username then password. Once your logged in, enter this sudo service lightdm stop This stops the x-server allowing you to install the downloaded nvidia drivers
  3. Navigate to the directory of the downloaded driver, then make it executable by using this chmod +x "drver.run" without the quotes. This will make it executable and able to install
  4. Next, just enter ./the nvidia driver to run it and allow it to install, it will prompt you every now and then, choose your answers based on how you want to install (I'd recommend install the 32-bit binaries when prompted if you're running 64-bit).
  5. If no major errors arise, you should be good. Let me know what happens and I'll see what I can do.
You can try removing edgers ppa and getting your drivers from mamarley. My 346 drivers from there work great. Not sure what is different but the edgers 346 didn't work for me but marley's did.
sudo add-apt-repository ppa:mamarley/nvidia
sudo apt-get update
sudo apt-get install nvidia-340
cP4n
  • 285
Finally i could figure this out !!
the answer is here http://www.noobslab.com/2014/12/use-nvidia-graphics-drivers-in.html
Thank you all for participating !! Love you all !
