I have just installed Ubuntu 14.04 on my nexus 4 and I am getting this error:
This phone needs restoring from a PC or service center.
You must be on kitkat (4.4.4) or earlier to flash Ubuntu Touch. If you are on Lollipop (5.0 or 5.0.2) you will get this failure. Fastboot flash the kitkat factory image first, then you will be able to successfully flash Ubuntu touch.
I just hit this message while trying to flash an updated Ubuntu Touch image, but I already had Ubuntu installed, not android. Here's how I recovered:
ubuntu-device-flash process still running.Use ubuntu-device-flash to try again. Specifically I used:
ubuntu-device-flash touch --bootstrap --developer-mode --channel ubuntu-touch/devel-proposed
Please note that the above will completely wipe your device and install the latest devel-proposed image (currently 15.04). If this is not what you want, refer to ubuntu-device-flash -h to see the available options.
I've seen this lots of times. When you perform the device flash command, on your phone you will eventually come to prompt with a few options like reboot in recovery mode, restore device, etc. Don't select anything! If you select any of the options, you will likely get that error after the phone reboots automatically. Just leave it alone and be patient, it will sit on that screen for several minutes before auto-reboot.
If it lingers on that prompt screen indefinitely, restart the process of device flash, by booting in the boot loader again, except before you run the device flash command, use your volume buttons to select "Recovery" mode in the boot loader - this is option in big letters in the top part of the screen - then commence with device flash. You may still get the other prompt again, but again, do nothing, just be patient.
