-1
When I use sudo apt-get -f install in terminal, the following happens:
Do you want to continue? [Y/n] y
(Reading database ... 237694 files and directories currently installed.)
Preparing to unpack .../linux-tools-3.16.0-31_3.16.0-31.41_amd64.deb ...
Unpacking linux-tools-3.16.0-31 (3.16.0-31.41) ...
dpkg: error processing archive /var/cache/apt/archives/linux-tools-3.16.0-31_3.16.0-31.41_amd64.deb (--unpack):
 trying to overwrite '/usr/lib/libcpupower.so.3.16.0-31', which is also in package linux-lts-utopic-tools-3.16.0-31 3.16.0-31.41~14.04.1
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
muru
  • 207,228
If you are running 14.10, you should not have linux-lts-utopic-tools-3.16.0-31. Where did you get that anyway?
Lesson one: use your package manager.
Unlike windows, where you search for and download exe files to install programs or applications, in linux you use the package manager (apt-get).
Open a terminal and execute the following commands:
sudo apt-get update
sudo apt-get autoremove
sudo apt-get autoclean
sudo apt-get purge linux-lts-utopic-tools-3.16.0-31 linux-tools-3.16.0-31
sudo apt-get install linux-tools-generic
If you need to search for software to install, use the synaptic-package-manager
sudo apt-get install synaptic
to run synaptic:
sudo synaptic
to do a command line search for available software:
apt-cache search linux-tools
to narrow the search use grep:
apt-cache search linux-tools | grep tools
to uninstall software, use apt-get purge:
sudo apt-get purge linux-tools-generic
to install, use apt-get install:
to reinstall, use apt-get install --reinstall:
sudo apt-get install --reinstall linux-tools-generic
to install basic updates
sudo apt-get update
sudo apt-get upgrade
to install system updates
sudo apt-get update
sudo apt-get dist-upgrade
mchid
  • 44,904
  • 102
  • 162
Try to remove the problematic package
sudo apt-get remove linux-tools-3.16.0-31
then fix the packages
sudo apt-get -f
and then install it again
sudo apt-get update && sudo apt-get upgrade sudo apt-get install linux-tools-generic
Yuri
  • 346
