  • I installed Ubuntu on my EasyNote-TM86 today.
  • I can't access any websites although I am connected to my router.
  • Other devices (including my laptop before I installed Ubuntu) are able to establish a connection/load websites.
  • Security is WPA/WPA2
From a search sudo dpkg-reconfigure resolvconf should make /etc/resolv.conf but mine only contains nameserver 127.0.1.1
Jeremy31
  • 13,293
My internet connection got lost after I upgraded from Ubuntu 16.04 to 18.04. After troubleshooting, I found /etc/resolv.conf empty
I also checked the file /etc/resolvconf/resolv.conf.d/tail and found it empty.
I added the line nameserver 8.8.8.8
Everything resolved.
Couple of things to do:
Restart network manager
Network manager on my machine is weird. The indicator may show the machine is connected but i cannot ping anything, mostly after startup. What solves it is sudo service network-manager restart
Delete system-connections
Network manager stores config for every connection in /etc/NetworkManager/system-connections/ directory. I've noticed that for many users here on askubuntu it has been sufficient to delete every file in that folder and try reconnecting to their network.
Remove needless stuff from resolv.conf
1    # Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
2        #     DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
3        nameserver 8.8.8.8 | sudo tee -a /etc/resolv/conf.d/head
4        printtf nnameserver
5        nameserver 8.8.8.8 | sudo tee -a /etc/resolvconf/resolv.conf.d/head
This is your resolv.conf file as you posted. Remove lines sudo tee from both /etc/resolv/conf.d/head and /etc/resolv.conf.d/base, as well as the printf line
Your base and head files should only contain nameserver 8.8.8.8 line.
Try deleting /run/resolvconf/resolv.conf
/etc/resolv.conf file is actually symbolic link to /run/resolvconf/resolv.conf file. Delete that actual file, edit head and base files, reboot.
Try adding other DNS in nm-connection-editor
Open nm-connection-editor, either in command line, or under network-indicator drop down menu (Edit Connections). Find your desired network. Select Edit. Under IPv4 settings, select "Automatic (DHCP) Address Only", then add 208.67.220.220 on the "Additional DNS Servers" line
For more info on the subject, refer to my question and answer here. Let me know if this answer was helpful or whether the problem persists
