Ok so here is every error that I get during sudo apt-get update or any sudo apt-get operation
BEFORE YOU LEAVE PLEASE READ! (thank you ^^)
(Remembered to add this after finishing the text: I'm using ubuntu 13.04 by the way!)
I do not know how to create a sploiler so the code or the whole terminal will be provided in the end. I will just explain my situation.
So I tried to get Ubuntu (and because I was desperate I tried any distro that was available(debian)) or just linux to work, I ended up getting Ubuntu to work, it was a glorious moment! But the glorious moment quickly vanished away as the most practical use also fades away, yes, I am talking about the Sudo apt-get command or operation.
My android phone is a samsung galaxy s4, some specs are provided:
Model : "APQ8064T"
Cores : "4"
Architecture : "Krait 300"
Revision : "r1p0"
Process : "28nm"
Clock Speed : "384 MHZ - 1.89 GHz" #Pretty much a fast phone!
GPU Vendor : "Qualcomm"
GPU Renderer : "Adreno (TM) 320 @ 450 MHz"
Scaling Governor : Currently set to "ondemand"
So I mean the phone could easily run android and ubuntu at the same time.
Now, the way I did this was following a tutorial which is : HERE
I followed the steps, I did it the "vnc" method, where you basically run Ubuntu in Text Mode on an ADB SHELL; or TERMINAL EMULATOR; and allow vnc connections to it. I pretty much don't use it as the connection is slow, but it is broken anyways. You need a .img file for the use of it. It uses busybox to mount a loop devices or some thing like that and VOILA just like magic, it runs perfectly! ... Or so I thought, anyway from what I can see is that it runs using armhf, my phone is using
Kernel Architecture : "armv7l"
So I'm guessing it means what architecture It is using. It does over heat quiet a bit (47c) but it only uses two cores at medium to high usage (that's 918 MHz and 1350 respectively!)
Here is some of that text below, I already tried to edit the sources.list but it didn't work, I removed the "port.ubuntu", changed it to "release.ubuntu" and also "old-release.ubuntu" nothing seems to work.
Now here is those 404 errors:
root@jflte:/ # sh /sdcard/ubuntu.sh
Making mount points and mounting to them...
Connecting to /sdcard...
Putting in some settings...
net.ipv4.ip_forward = 1
ubuntu is configured with SSH and VNC servers that can be accessed from the IP:
(You will see an error about wlan0 if your WiFi is disabled. Safe to ignore.)
----------------- OKAY, starting Ubuntu! -----------------
Start VNC server? (y/n)
y
Start SSH server? (y/n)
y
Now enter the screen size you want in pixels (e.g. 800x480), followed by [ENTER]:
1920x1080
New 'X' desktop is localhost:0
Starting applications specified in /home/ubuntu/.vnc/xstartup
Log file is /home/ubuntu/.vnc/localhost:0.log
If you see the message 'New 'X' Desktop is localhost:0' then you are ready to VNC into your ubuntu OS..
If connection from a different machine on the same network as the android device use the address below:
192.168.0.87
If using androidVNC, change the 'Color Format' setting to 24-bit colour, and once you've VNC'd in, change the 'input mode' to touchpad (in settings)
* Starting OpenBSD Secure Shell server sshd [ OK ]
Save settings as defaults? (y/n) (You can always change it later in the app)
n
To shut down the Linux environment, just enter 'exit' at this terminal - and WAIT for all shutdown routines to finish!
root@localhost:/# sudo apt-get update
Ign http://releases.ubuntu.com raring Release.gpg
Err http://releases.ubuntu.com raring/main Sources
404 Not Found [IP: 91.189.88.148 80]
Err http://releases.ubuntu.com raring/restricted Sources
Err http://releases.ubuntu.com raring/universe Sources
Err http://releases.ubuntu.com raring/main armhf Packages
Err http://releases.ubuntu.com raring/restricted armhf Packages
Err http://releases.ubuntu.com raring/universe armhf Packages
Ign http://releases.ubuntu.com raring/main Translation-en
Ign http://releases.ubuntu.com raring/restricted Translation-en
Ign http://releases.ubuntu.com raring/universe Translation-en
W: Failed to fetch http://releases.ubuntu.com/dists/raring/main/source/Sources 404 Not Found [IP: 91.189.88.148 80]
W: Failed to fetch http://releases.ubuntu.com/dists/raring/restricted/source/Sources 404 Not Found [IP: 91.189.88.148 80]
W: Failed to fetch http://releases.ubuntu.com/dists/raring/universe/source/Sources 404 Not Found [IP: 91.189.88.148 80]
W: Failed to fetch http://releases.ubuntu.com/dists/raring/main/binary-armhf/Packages 404 Not Found [IP: 91.189.88.148 80]
W: Failed to fetch http://releases.ubuntu.com/dists/raring/restricted/binary-armhf/Packages 404 Not Found [IP: 91.189.88.148 80]
W: Failed to fetch http://releases.ubuntu.com/dists/raring/universe/binary-armhf/Packages 404 Not Found [IP: 91.189.88.148 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
root@localhost:/#
So It is the sources.list file, please help! I can't wait to get this working :) I have already come so far...
