This is what I use, works well always.
A combination of various tutorials.
Tested on Ubuntu 16.04LTS too.
Step A-- Make sure that ufw is installed
sudo apt-get install ufw
Step B -- Configure your network interfaces.
sudo nano /etc/network/interfaces
Configure the interfaces file to be something like this below:
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
source /etc/network/interfaces.d/*
# The loopback network interface
auto lo
iface lo inet loopback
# The WAN primary network interface
iface eth0 inet static
address 182.xxx.xxx.xxx
netmask xxx.xxx.xxx.xxx
gateway xxx.xxx.xxx.xxx
#LAN side interface
auto eth1
iface eth1 inet static
address 192.168.0.1
netmask 255.255.255.0
network 192.168.0.0
broadcast 192.168.0.255
address 192.168.0.1
Save the file by selecting CTRL-X from nano or any other editor you prefer.
Step C -- Allow IP Forward.
Set the forwarding.
Edit the file /etc/sysctl.conf
sudo nano /etc/sysctl.conf
Remove the comment on this line # net.ipv4.ip_forward=1 for it to be net.ipv4.ip_forward=1
Save changes and move to next step.
Step D -- Masquerading/forwarding rules
sudo iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
sudo iptables -A FORWARD -i eth0 -o eth1 -m state --state RELATED,ESTABLISHED -j ACCEPT
sudo iptables -A FORWARD -i eth1 -o eth0 -j ACCEPT
Persist iptables changes
sudo su
sudo iptables-save > /etc/iptables.rules
sudo nano /etc/network/if-pre-up.d/iptables
Enter this content:
#!/bin/sh
iptables-restore < /etc/iptables.rules
exit 0
Save changes
Then edit/create next iptables file
sudo nano /etc/network/if-post-down.d/iptables
Enter this content:
#!/bin/sh
iptables-save -c > /etc/iptables.rules
if [ -f /etc/iptables.rules ]; then
fi
exit 0
Save changes.
Make both files executable
sudo chmod +x /etc/network/if-post-down.d/iptables
sudo chmod +x /etc/network/if-pre-up.d/iptables
Step E -- Finalize with ufw configuration
sudo nano /etc/default/ufw
Change parameter forward policy to accept
DEFAULT_FORWARD_POLICY="ACCEPT"
Save changes.
I have my SSH on port 49870, so I also allowed ufw to accept connections on that port:
sudo ufw allow 49870
Step F -- Do not forget to enable ufw.
sudo ufw enable
At this stage, just reboot your system.
Then all LAN devices can use it as main gateway.
On a side note, ufw is very convenient to manage firewall settings.
