firt time start mining litecoin "error -11...." i'd like to understand more abou how to fix this..
  • Ubuntu 14.04.2 LTS (Trusty Tahr)
  • 64 bit notebook
  • videocard: ATI Radeon™ HD 5000 Series model: 5470M
  • cgminer: 3.7.2
  • 3D Acelerator active $ glxinfo | grep render direct rendering: Yes OpenGL renderer string: AMD Mobility Radeon HD 5000 Series GL_KTX_buffer_region, GL_NV_blend_square, GL_NV_conditional_render, GL_KTX_buffer_region, GL_NV_blend_square, GL_NV_conditional_render,
  • cgminer: $./cgminer -n [2015-02-28 00:55:42] CL Platform 0 vendor: Advanced Micro Devices, Inc.
    [2015-02-28 00:55:42] CL Platform 0 name: AMD Accelerated Parallel Processing
    [2015-02-28 00:55:42] CL Platform 0 version: OpenCL 1.2 AMD-APP (1411.4)
    [2015-02-28 00:55:42] Platform 0 devices: 1
    [2015-02-28 00:55:42] 0 Cedar
    [2015-02-28 00:55:42] GPU 0 AMD Mobility Radeon HD 5000 Series hardware monitoring enabled [2015-02-28 00:55:42] 1 GPU devices max detected
    [2015-02-28 00:55:42] USB all: found 6 devices - listing known devices
    [2015-02-28 00:55:42] No known USB devices
  • mining scrypt:
    !/bin/sh
export DISPLAY=:0 export GPU_MAX_ALLOC_PERCENT=100 export GPU_USE_SYNC_OBJECTS=1 ./cgminer --scrypt --url=stratum+tcp://us2.pool.org:3333 --userpass=my.worker:1 --url=stratum+tcp://us.lite.pool.org:3333 --userpass=my.worker:1 --failover-only --shaders=80 --intensity=19
  • ERROR -11 starting scrypt: [2015-02-28 00:51:13] Started cgminer 3.7.2 [2015-02-28 00:51:13] Started cgminer 3.7.2 [2015-02-28 00:51:13] Probing for an alive pool [2015-02-28 00:51:14] Pool 0 difficulty changed to 1024 [2015-02-28 00:51:14] Error -11: Building Program (clBuildProgram) [2015-02-28 00:51:14] "/tmp/OCL2443T5.cl", line 762: warning: variable "ySIZE" was declared but never referenced
    const uint ySIZE = (1024/LOOKUP_GAP+(1024%LOOKUP_GAP>0));
"/tmp/OCL2443T5.cl", line 814: error: work group size exceeds the maximum
[2015-02-28 00:51:14] Failed to init GPU thread 0, disabling device 0 [2015-02-28 00:51:14] Restarting the GPU from the menu will not fix this. [2015-02-28 00:51:14] Try restarting cgminer. Press enter to continue:
I see you problem within the title to your question anything x86 is 32-bit and x86 should be nowhere near anything 64-bit and of amd64 so for some reason you have the two combined also i should note that most Notebook laptops are 32-bit so simply i believe you problem lies in the lack of research done before installation of Ubuntu...
Rule #1 of computer programming- Proper preparation = positive outcome...but Improper Preparation = negative outcome.
dont worry i made a few mistakes when i first learned computer programing even deleted Windows 7 and couldn't get Ubuntu on but i learned to research before i went running and now i would consider myself a great computer programmer so sadly you might have to re install the pre-set os and then reinstall Ubuntu.
Tactux
  • 166
