I recently installed Ubuntu: 14.10, Kernel: 3.16.0-31-generic. I have some network problems. My Laptop is a Lenovo Yoga 13. I had some issues getting the network adapter to work, but it works now - sometimes! Here is what happens:
At work, everything works like a charm. I have had no problems what so ever!
At home, Wifi connection shows a "?" in the toolbar. Everything using the network connection stops responding. For example the file browser, when I try to connect to something using SSH, my Bluefish editor, also using SSH. When I try to edit network setting, it also stops responding. I have to force quit these applications... "“Settings” is not responding. You may choose to wait a short while for it to continue or force the application to quit entirely."
The browser is working for a while, but then it looses connection. However the browser does not stop responding, it just looses connection.
If I try to reboot, the system freezes completely.
On my other devices there is no problems connecting to this network.
Some commands, with information:
nm-tool:
NetworkManager Tool
State: connected (global)
- Device: wlan0 [1gbitinternet 1] ---------------------------------------------
Type: 802.11 WiFi
Driver: rtl8723au
State: connected
Default: yes
HW Address: 2C:D0:5A:F3:72:E2
Capabilities:
Speed: 72 Mb/s
Wireless Properties
WEP Encryption: yes
WPA Encryption: yes
WPA2 Encryption: yes
rfkill list all
0: ideapad_wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
1: ideapad_bluetooth: Bluetooth
Soft blocked: yes
Hard blocked: no
2: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
sudo lshw -class network
*-network
description: Wireless interface
physical id: 1
bus info: usb@1:1.4
logical name: wlan0
serial: 2c:d0:5a:f3:72:e2
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=rtl8723au driverversion=3.16.0-31-generic firmware=N/A ip=192.168.1.45 link=yes multicast=yes wireless=IEEE 802.11abgn
lsusb
Bus 002 Device 004: ID 5986:029c Acer, Inc
Bus 002 Device 003: ID 2047:0855 Texas Instruments
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 006: ID 04f3:000a Elan Microelectronics Corp.
Bus 001 Device 005: ID 0bda:1724 Realtek Semiconductor Corp.
Bus 001 Device 004: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 003: ID 0781:5571 SanDisk Corp. Cruzer Fit
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
modinfo rtl8723au
modinfo: ERROR: Module rtl8723au not found.
sudo rfkill list
Soft blocked: no
Hard blocked: no
Soft blocked: no
Hard blocked: no
Soft blocked: no
Hard blocked: no
git log -n 1 --oneline
bd3ef04 rtl8723au: Allow build on armv7l
Maybe the wrong driver is enabled?
sudo modinfo 8723au
filename: /lib/modules/3.16.0-31-generic/kernel/drivers/net/wireless/8723au.ko
version: v4.1.6_7336.20130426
author: Realtek Semiconductor Corp.
description: Realtek Wireless Lan Driver
license: GPL
srcversion: 4F10D2E0FAC6F67FFD05DE4
alias: usb:v0BDAp0724d*dc*dsc*dp*icFFiscFFipFFin*
alias: usb:v0BDAp1724d*dc*dsc*dp*icFFiscFFipFFin*
alias: usb:v0BDAp8724d*dc*dsc*dp*icFFiscFFipFFin*
depends:
vermagic: 3.16.0-31-generic SMP mod_unload modversions
parm: rtw_ips_mode:The default IPS mode (int)
parm: rtw_regulatory_id:int
parm: ifname:The default name to allocate for first interface (charp)
parm: if2name:The default name to allocate for second interface (charp)
parm: rtw_initmac:charp
parm: rtw_channel_plan:int
parm: rtw_chip_version:int
parm: rtw_rfintfs:int
parm: rtw_lbkmode:int
parm: rtw_network_mode:int
parm: rtw_channel:int
parm: rtw_wmm_enable:int
parm: rtw_vrtl_carrier_sense:int
parm: rtw_vcs_type:int
parm: rtw_busy_thresh:int
parm: rtw_ht_enable:int
parm: rtw_cbw40_enable:int
parm: rtw_ampdu_enable:int
parm: rtw_rx_stbc:int
parm: rtw_ampdu_amsdu:int
parm: rtw_lowrate_two_xmit:int
parm: rtw_rf_config:int
parm: rtw_power_mgnt:int
parm: rtw_smart_ps:int
parm: rtw_low_power:int
parm: rtw_wifi_spec:int
parm: rtw_antdiv_cfg:int
parm: rtw_antdiv_type:int
parm: rtw_enusbss:int
parm: rtw_hwpdn_mode:int
parm: rtw_hwpwrp_detect:int
parm: rtw_hw_wps_pbc:int
parm: rtw_max_roaming_times:The max roaming times to try (uint)
parm: rtw_80211d:Enable 802.11d mechanism (int)
parm: rtw_btcoex_enable:Enable BT co-existence mechanism (int)
parm: rtw_notch_filter:0:Disable, 1:Enable, 2:Enable only for P2P (uint)
parm: debug:Set debug level (1-9) (default 1) (int)
I still have these errors:
dmesg | grep -e 8723 -e 80211 | tail -n15
[ 11.540092] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 11.540094] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 11.540095] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 11.540097] cfg80211: (5250000 KHz - 5330000 KHz @ 40000 KHz), (N/A, 2000 mBm), (0 s)
[ 11.540098] cfg80211: (5490000 KHz - 5710000 KHz @ 40000 KHz), (N/A, 2700 mBm), (0 s)
[ 11.540099] cfg80211: (57240000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 11.626988] RTL8723AU: ERROR send eapol packet
[ 11.639382] RTL8723AU: ERROR send eapol packet
[ 11.639679] RTL8723AU: ERROR set pairwise key to hw: alg:4(WEP40-1 WEP104-5 TKIP-2 AES-4) camid:4
[ 325.669099] RTL8723AU: ERROR set ssid [1gbitinternet] fw_state = 0x00000008
[ 325.773209] RTL8723AU: ERROR start auth
[ 325.776061] RTL8723AU: ERROR auth success, start assoc
[ 325.801791] RTL8723AU: ERROR send eapol packet
[ 325.828360] RTL8723AU: ERROR send eapol packet
[ 325.829611] RTL8723AU: ERROR set pairwise key to hw: alg:4(WEP40-1 WEP104-5 TKIP-2 AES-4) camid:4
