I'm trying to do something fairly specific and I was wondering if anyone had some suggestions for ways to do it.
I'm working on a program and for it I need an application to do the following utilizing a webcam:
  1. Be able to locally broadcast live video from a webcam to the user on the screen at a decent frame-rate (somewhere around 10 would be nice)
  2. From this live broadcast, be able to take single image snapshots at a commanded time
I'm looking for something that runs on the command line, preferably. I've tried using VLC which is nice for the first part, but in order to take a screenshot, I haven't found a way to do so using the command line. In order for that to work in my application I would need to simulate keystrokes with an active window which may make it a bit difficult to implement.
If anyone has any other suggestions as well using basic terminal commands that would also work, I'm fully open to them.
The easiest way to accomplish this, would be to do the exact opposite of what you're trying to do:
(so basically a combination of both above answers)
I would: take a minimum of 16 fps as that is the minimum our brain needs to see smooth motion
If this is for a web application, you wouldn't even have to convert these still images to a video stream as you could use JavaScript to display 16 images every second (refresh page 16 times per second) provided you've got enough bandwidth available to upload 16 pictures / second. But that depends on your specific use case.
Fabby
  • 35,017
