Once again I need a workaround to deal with my almost broken notebook graphics card: It does not wake up after suspending!
The Ubuntu 14.10 system is waking up, but the display stays off, so I have to press the Power button and blindly navigate to the "Shutdown" option, to avoid a hard power off.
I already disabled suspending for all of my user accounts by following this answer. However, I now have seen three times when it actually DID do suspending!
That was:
- once after I let my notebook on over night (can't remember last state...)
- once after I closed the lid before I logged into any user account after boot
- once when the notebook was not in use quite a long time (few hours max.) after leaving it on the lock-screen
I think somehow it is still allowed for the system to use suspension and that there is no rule set for the login/lock screen.
Now, can I disable the suspension functionality there too?
Update:
I recently installed lubuntu-desktop to try LXDE instead of Unity. Now in Lubuntu mode, I can not disable suspending at all. Closing the lid does a suspend which also causes the screen to die until I reboot.
So the solution has to be independent of the used DE!
Edit:
Computer information: lspci -v
00:00.0 Host bridge: Intel Corporation Mobile 945GM/PM/GMS, 943/940GML and 945GT Express Memory Controller Hub (rev 03)
Subsystem: QUANTA Computer Inc Device 0753
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
00:01.0 PCI bridge: Intel Corporation Mobile 945GM/PM/GMS, 943/940GML and 945GT Express PCI Express Root Port (rev 03) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
Memory behind bridge: dc000000-ddffffff
Prefetchable memory behind bridge: 00000000c0000000-00000000cfffffff
Kernel driver in use: pcieport
00:1b.0 Audio device: Intel Corporation NM10/ICH7 Family High Definition Audio Controller (rev 02)
Subsystem: QUANTA Computer Inc Softmodem
Flags: bus master, fast devsel, latency 0, IRQ 46
Memory at de300000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 1 (rev 02) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00002000-00002fff
Memory behind bridge: d8000000-d9ffffff
Prefetchable memory behind bridge: 00000000d2000000-00000000d3ffffff
00:1c.1 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 2 (rev 02) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=08, subordinate=08, sec-latency=0
I/O behind bridge: 00003000-00003fff
Memory behind bridge: d6000000-d7ffffff
Prefetchable memory behind bridge: 00000000d0000000-00000000d1ffffff
00:1c.2 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 3 (rev 02) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
I/O behind bridge: 00004000-00004fff
Memory behind bridge: da000000-dbffffff
Prefetchable memory behind bridge: 00000000d4000000-00000000d5ffffff
00:1d.0 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #1 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
I/O ports at 1800 [size=32]
Kernel driver in use: uhci_hcd
00:1d.1 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #2 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 19
I/O ports at 1820 [size=32]
00:1d.2 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #3 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 18
I/O ports at 1840 [size=32]
00:1d.3 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #4 (rev 02) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 16
I/O ports at 1860 [size=32]
00:1d.7 USB controller: Intel Corporation NM10/ICH7 Family USB2 EHCI Controller (rev 02) (prog-if 20 [EHCI])
Memory at de304000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci-pci
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e2) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=05, subordinate=07, sec-latency=32
I/O behind bridge: 00005000-00005fff
Memory behind bridge: de000000-de0fffff
00:1f.0 ISA bridge: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge (rev 02)
Kernel driver in use: lpc_ich
00:1f.2 IDE interface: Intel Corporation 82801GBM/GHM (ICH7-M Family) SATA Controller [IDE mode] (rev 02) (prog-if 80 [Master])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 19
I/O ports at 01f0 [size=8]
I/O ports at 03f4
I/O ports at 0170 [size=8]
I/O ports at 0374
I/O ports at 18b0 [size=16]
Kernel driver in use: ata_piix
00:1f.3 SMBus: Intel Corporation NM10/ICH7 Family SMBus Controller (rev 02)
Flags: medium devsel, IRQ 10
I/O ports at 18e0 [size=32]
01:00.0 VGA compatible controller: NVIDIA Corporation G72M [GeForce Go 7400] (rev a1) (prog-if 00 [VGA controller])
Flags: fast devsel, IRQ 16
Memory at dd000000 (32-bit, non-prefetchable) [size=16M]
Memory at c0000000 (64-bit, prefetchable) [size=256M]
Memory at dc000000 (64-bit, non-prefetchable) [size=16M]
Expansion ROM at <unassigned> [disabled]
02:00.0 Network controller: Intel Corporation PRO/Wireless 3945ABG [Golan] Network Connection (rev 02)
Subsystem: Intel Corporation WM3945ABG MOW2
Flags: bus master, fast devsel, latency 0, IRQ 45
Memory at d8000000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: iwl3945
04:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8055 PCI-E Gigabit Ethernet Controller (rev 10)
Flags: bus master, fast devsel, latency 0, IRQ 44
Memory at da000000 (64-bit, non-prefetchable) [size=16K]
I/O ports at 4000 [size=256]
[virtual] Expansion ROM at da020000 [disabled] [size=128K]
Kernel driver in use: sky2
05:01.0 CardBus bridge: Texas Instruments PCIxx12 Cardbus Controller
Flags: bus master, medium devsel, latency 168, IRQ 18
Memory at f0000000 (32-bit, non-prefetchable) [size=4K]
Bus: primary=05, secondary=06, subordinate=07, sec-latency=176
Memory window 0: f4000000-f7ffffff (prefetchable)
Memory window 1: f8000000-fbffffff
I/O window 0: 00005000-000050ff
I/O window 1: 00005400-000054ff
16-bit legacy interface ports at 0001
Kernel driver in use: yenta_cardbus
05:01.1 FireWire (IEEE 1394): Texas Instruments PCIxx12 OHCI Compliant IEEE 1394 Host Controller (prog-if 10 [OHCI])
Flags: bus master, medium devsel, latency 64, IRQ 19
Memory at de005000 (32-bit, non-prefetchable) [size=2K]
Memory at de000000 (32-bit, non-prefetchable) [size=16K]
Kernel driver in use: firewire_ohci
05:01.2 Mass storage controller: Texas Instruments 5-in-1 Multimedia Card Reader (SD/MMC/MS/MS PRO/xD)
Flags: bus master, medium devsel, latency 64, IRQ 18
Memory at de004000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: tifm_7xx1
05:01.3 SD Host controller: Texas Instruments PCIxx12 SDA Standard Compliant SD Host Controller (prog-if 01)
Memory at de005800 (32-bit, non-prefetchable) [size=256]
Kernel driver in use: sdhci-pci
Memory info: free -m
total used free shared buffers cached
Mem: 2017 1310 707 14 32 507
-/+ buffers/cache: 770 1247
Swap: 892 1 891
