Filesystem      Size  Used Avail Use% Mounted on
/dev/sda6       9.1G  8.4G  214M  98% /
none            4.0K     0  4.0K   0% /sys/fs/cgroup
udev            1.9G  8.0K  1.9G   1% /dev
tmpfs           390M  1.2M  389M   1% /run
none            5.0M     0  5.0M   0% /run/lock
none            2.0G  8.8M  1.9G   1% /run/shm
none            100M   52K  100M   1% /run/user
/dev/sda4       1.9G   89M  1.7G   6% /boot
/dev/sda7        54G  6.5G   45G  13% /home
/dev/sda2       274G  166G  109G  61% /media/ubuntu/74386C84386C46E8
/dev/sda5       355G  337G   19G  95% /media/ubuntu/Nouveau nom
I have not enough space in my / directory and want to move /run/shm at my /home.
Rinzwind
  • 309,379
Please read What are "/run/lock" and "/run/shm" used for? and see why what you are asking is not possible and not going to help you create space on / and that you are incorrectly interpreting this data: /run/*/ is a tmpfs; not actual space. Then none in the file system column indicates this is not an actual hard disk. You need to analyse why / is 8.4Gb.
I would advise you to ...
  • check your log files. On a desktop 8.4 GB is a lot. For a server the 9.1 is not enough. I have a desktop version with MySQL (so technically it is a server) running and some test databases for data analyses. My root stays around 10Gb and 15Gb so I would advise a 20Gb if you use this as a server too. But if this is a normal desktop system there might be some log files that contain errors and grow. Fix the error, delete the old logs and you will have more free space in /.
  • merge / and /home. There is not really any reason any more to have a separate /home. During installation you can nowadays opt to keep your current documents. If you do not want to merge you can also opt to shrink /home and add the unallocated space to /. Both can be done from an Ubuntu Live DVD with gParted installed or a gParted Live DVD.
Rinzwind
  • 309,379
