I found a few questions that were similar to this but none of them were enough like my particular case to be of any use.
Whenever I open Steam, a terminal opens up:
Steam needs to install these additional packages:
    libgl1-mesa-dri:i386, libgl1-mesa-glx:i386
I enter my password and hit enter:
Reading package lists... Done
Building dependency tree
 libgl1-mesa-glx:i386 : Depends: libglapi-mesa:i386 (= 10.5.0~git20150204.661c8bb2-0ubuntu0ricotz~trusty)
 unity-control-center : Depends: libcheese-gtk23 (>= 3.4.0) but it is not going to be installed
                        Depends: libcheese7 (>= 3.0.1) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Press return to continue:
This is a fresh install of Ubuntu 14.04 and Steam. The last time I tried this, I ended up screwing the system up trying to resolve these various dependencies. What steps do I need to take to fix this?
If it matters, this is 64-bit, I'm using my gtx980 graphics card's NVIDIA driver installed from a PPA, and I can provide any hardware info if necessary.
I tried using the sudo apt-get install libgl1-mesa-dri:i386 libgl1-mesa-glx:i386 command and a second time with the -f option, with the latter resulting in:
