How to disable Webmin starts on boot on Ubuntu 14? Due security reasons, I want to run it manualy when I really will use it.
Asked
Active
Viewed 1.1k times
You can either manually edit the scripts but the best way is to run
sudo update-rc.d webmin enable
and all the required entries will be made cleanly - less risk of breakage of essential startup scripts.
and the reverse to disable
sudo update-rc.d webmin disable
CRTLBREAK
- 131
You can disable Webmin starting at boot from the Webmin interface, in the Webmin Configuration module. At the bottom of the module window is the option to set when Webmin starts. You can invoke Webmin to start via command-line sudo service webmin start when configured not to start at boot.
douggro
- 2,587
