68
I've been trying to find a way to filter a line that has the word "lemon" and "rice" in it. I know how to find "lemon" or "rice" but not the two of them. They don't need to be next to the other, just one the same line of text.
αғsнιη
  • 36,350
Sebastian
  • 785
7 Answers7
79
"Both on the same line" means "'rice' followed by random characters followed by 'lemon' or the other way around".
In regex that is rice.*lemon or lemon.*rice. You can combine that using a |:
grep -E 'rice.*lemon|lemon.*rice' some_file
If you want to use normal regex instead of extended ones (-E) you need a backslash before the |:
grep 'rice.*lemon\|lemon.*rice' some_file
For more words that quickly gets a bit lengthy and it's usually easier to use multiple calls of grep, for example:
grep rice some_file | grep lemon | grep chicken
dessert
  • 40,956
32
You can pipe the output of first grep command to another grep command and that would match both the patterns. So, you can do something like:
grep <first_pattern> <file_name> | grep <second_pattern>
or,
cat <file_name> | grep <first_pattern> | grep <second_pattern>
Example:
Let's add some contents to our file:
$ echo "This line contains lemon." > test_grep.txt
$ echo "This line contains rice." >> test_grep.txt
$ echo "This line contains both lemon and rice." >> test_grep.txt
$ echo "This line doesn't contain any of them." >> test_grep.txt
$ echo "This line also contains both rice and lemon." >> test_grep.txt
What does the file contain:
$ cat test_grep.txt
Now, let's grep what we want:
$ grep rice test_grep.txt | grep lemon
We only get the lines where both the patterns match. You can extend this and pipe the output to another grep command for further "AND" matches.
Aditya
  • 13,616
23
Though the question asks for 'grep', I thought it might be helpful to post a simple 'awk' solution:
awk '/lemon/ && /rice/'
This can easily be extended with more words, or other boolean expressions besides 'and'.
muru
  • 207,228
David B.
  • 231
12
Another idea to finding the matches in any order is using:
grep with -P (Perl-Compatibility) option and positive lookahead regex (?=(regex)):
grep -P '(?=.*?lemon)(?=.*?rice)' infile
or you can use below, instead:
grep -P '(?=.*?rice)(?=.*?lemon)' infile
  • The .*? means matching any characters . that occurrences zero or more times * while they are optional followed by a pattern(rice or lemon). The ? makes everything optional before it (means zero or one time of everything matched .*)
(?=pattern): Positive Lookahead: The positive lookahead construct is a pair of parentheses, with the opening parenthesis followed by a question mark and an equals sign.
So this will return all lines with contains both lemon and rice in random order. Also this will avoid of using |s and doubled greps.
See also:
Advanced Grep Topics
αғsнιη
  • 36,350
10
This command returns matches for a line which has either foo or goo.
grep -e foo -e goo
This command return matches for lines which have both foo and goo in any order.
grep -e foo.*goo -e goo.*foo
netskink
  • 199
If we admit that providing an answer that is not grep based is acceptable, like the above answer based on awk, I would propose a simple perl line like:
$ perl -ne 'print if /lemon/ and /rice/' my_text_file
The search can be ignoring case with some/all of the words like /lemon/i and /rice/i. On most Unix/Linux machines perl is installed as well as awk anyway.
Here's a script to automate the grep piping solution:
#!/bin/bash
# Use filename if provided as environment variable, or "foo" as default
filename=${filename-foo}
grepand () {
# disable word splitting and globbing
IFS=
set -f
if [[ -n $1 ]]
then
grep -i "$1" ${filename} | filename="" grepand "${@:2}"
else
# If there are no arguments, assume last command in pipe and print everything
cat
fi
grepand "$@"
Jeff
  • 782
