in order to use darktable with OpenCL everytime before starting darktable I have to issue
sudo modprobe nvidia-uvm
sudo mknod -m 666 /dev/nvidia-uvm c 250 0
What is the right way to enable nvidia-uvm by default?
Regards, Oliver
Proper way to do this is described in CUDA documentation:
https://docs.nvidia.com/cuda/cuda-installation-guide-linux/index.html#runfile-verifications
Script from link above:
#!/bin/bash
/sbin/modprobe nvidia
if [ "$?" -eq 0 ]; then
Count the number of NVIDIA controllers found.
NVDEVS=lspci | grep -i NVIDIA N3D=echo "$NVDEVS" | grep "3D controller" | wc -l NVGA=echo "$NVDEVS" | grep "VGA compatible controller" | wc -l
N=expr $N3D + $NVGA - 1 for i in seq 0 $N; do mknod -m 666 /dev/nvidia$i c 195 $i done
mknod -m 666 /dev/nvidiactl c 195 255
else exit 1 fi
/sbin/modprobe nvidia-uvm
Find out the major device number used by the nvidia-uvm driver
D=grep nvidia-uvm /proc/devices | awk '{print $1}'
mknod -m 666 /dev/nvidia-uvm c $D 0 else exit 1 fi
iborko
  • 101
