i'm making a little shell script and i want to stock all files with same suffix in a table.
i want something like that :
path=/home/user/Documents
suffix="_suffix.txt"
and then a function that create a table name files and fill it with file in $path with $suffix suffix. result :
echo files[0]
-> /home/user/Documents/project_suffix.txt
echo files[1]
-> /home/user/Documents/html_suffix.txt
echo files[2]
-> /home/user/Documents/jokes_suffix.txt. etc...
I don't want to have in my list other files like "budget.txt"
Thanks for your answers ! ;)
muru
  • 207,228
This is fairly straightforward with recent versions of bash by using globbing and arrays, which is what I assume you mean by tables.
First create some test files:
path=/some/where
touch $path/{a,b,c}_suffix.txt
Here is an example that puts all files ending in _suffix.txt into the files array:
files=("$path"/*_suffix.txt)
To iterate over them you can do something like this:
for file in "${files[@]}"; do
  echo "$file"
done
Or:
for i in ${!files[@]}; do
  echo "${files[i]}"
done
Note, filenames with spaces and newlines in them will cause problems with this approach. In that case you are better of with a find and -print0 loop, see this answer for an example and this write-up for details.
Edit
As noted by muru, the whitespace problem may not be as problematic as it used to be, YMMV.
Thor
  • 3,678
What you call a table is usually called an array or a map. In bash, to create such an array:
path="/home/user/Documents"
files=( "$path"/*"$suffix" )
The * is a wildcard, which is expanded by the shell to all matching filenames (that have $path before it and $suffix after). The brackets (()) convert the expanded filenames into an array.
Then you can access each element (indexed from 0, instead of 1) using "${files[0]}", "${files[1]}", etc.
For example:
$ path=/tmp
$ suffix=_amd64.deb
$ files=( "$path"/*"$suffix" )
$ echo "${files[1]}" "${files[0]}"
/tmp/vim-athena_7.4.640-1~ppa1~t_amd64.deb /tmp/vim_7.4.640-1~ppa1~t_amd64.deb
muru
  • 207,228
