$ sudo apt-get install package-name:i386
Reading package lists... Done
Building dependency tree
E: Unable to locate package package-name:i386
$ sudo apt-get install ia32-libs
You might want to run 'apt-get -f install' to correct these:
google-chrome-stable : Depends: libnss3 (>= 3.14.3) but 3.13.1.with.ckbi.1.88-1ubuntu6 is to be installed
ia32-libs : Depends: ia32-libs-multiarch
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Asked
Active
Viewed 785 times
-2
I would say that this error is not due to the installation of the ia32-libs package, but it is a problem that has arisen before. Does the error also occur when you try to install any other package?
Try this:
sudo apt-get -f install
If it does not fix it, edit your question with the new info.
ferranrigual
- 126
- 5
