39
I'm trying to extract a rar file is first time is opened then its closed and to reopen the file is failed." an error occured while loading the archive manager" this alert message displayed
5 Answers5
77
Install unrar to open and extract rar archives.
  1. Open the terminal with ctrl + alt + t
  2. Run
    sudo apt install unrar
Now file-roller should open and extract rar archives without error.
If you cannot install unrar, you need to activate the multiverse repository; but, I assume you have them activated as they are by default.
pomsky
  • 70,557
mondjunge
  • 3,336
Something like this happened to me when a file was parted in some files, and I tried this from the command line:
unrar e "archive.part1.rar"
karel
  • 122,292
  • 133
  • 301
  • 332
Mike
  • 71
I have this problem fixed by installing b1freearchiver:
sudo apt-get install gdebi
wget b1.org/smart-download/0/os=deb64/b1freearchiver_current_stable_amd64.deb
sudo gdebi b1freearchiver_current_stable_amd64.deb
cmak.fr
  • 8,976
good suggestions above. However, what I found is that when I did a cd to the directory with the terminal it showed that it was a 'string' instead of a normal file. Then I tested something quick and it worked perfectly: I just deleted the empty space between the words in the filename, and right click 'extract' again and it extracted perfectly. So the solution might be that simple for you too, if you have a blank space in the file name. Example:
FILE NAME.rar change to -> FILE_NAME.rar
Hope that helps.
Zanna
  • 72,312
Here is an alternative way to use unrar. The benefit is that this version will keep the folder structure of the original .rar file.
unrar x -ad "archive.rar"
Daniel T
  • 5,339
