I tried to install Times New Roman font on my Ubuntu. I used this code formulation: sudo apt-get install msttcorefonts. Everything looked fine, until the screen showed a kind of agreement statement. I tried to enter the 'OK' there, but it didn't work. So, I thought the process of installing the font is done. Then, I restarted the computer. But, the font, I could find it in my Libreoffice. I wrote the same formulation again for installing it. But I got this notification:
dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
Can somebody help me to fix this? Thanks
muru
  • 207,228
Run sudo apt-get install -f and sudo dpkg --configure -a in a terminal. Restart/reboot may be necessary.
If you received any errors after running both commands, post them as a comment in this answer.
