13
I want to write a script that add a cron job to my crontab but without user intervention like editing a file using crontab -e. Is there a way to programatically manipulate the cron jobs from command line? Any suggestion on how to do that? Thanks in advance.
Ither
  • 233
To install a crontab:
echo "1 1  * * *  test" | crontab -
should do the trick.
NOTICE that this substitutes the whole crontab. You have to save the value it had with crontab -l if you just want to add/edit things. For example
(crontab -l && echo "1 1  * * *  test") | crontab -
will add the line to your crontab.
Rmano
  • 32,167
How about the following:
crontab -l | some-editing-command | EDITOR=cat crontab -e
The first part of the pipe lists the current crontab, the second part is supposed to modify it in a sensible way, and the third part reinstalls it using cat as the "editor", as suggested by @muru.
krlmlr
  • 3,447
