I have a Acer V5 122P, only WIFI, without Ethernet port and I can't connect to WiFi,
I have this information:
$ ifconfig
lo        Link encap:Bucle local
          Direc. inet:127.0.0.1  Másc:255.0.0.0
          Dirección inet6: ::1/128 Alcance:Anfitrión
          ACTIVO BUCLE FUNCIONANDO  MTU:65536  Métrica:1
          Paquetes RX:289 errores:0 perdidos:0 overruns:0 frame:0
          Paquetes TX:289 errores:0 perdidos:0 overruns:0 carrier:0
          colisiones:0 long.colaTX:0
          Bytes RX:21633 (21.6 KB)  TX bytes:21633 (21.6 KB)
$ lspci | grep Network
01:00.0 Network controller: Broadcom Corporation BCM43142 802.11b/g/n (rev 01)
$ lspci -vvnn | grep -A 9 Network
01:00.0 Network controller [0280]: Broadcom Corporation BCM43142 802.11b/g/n [14e4:4365] (rev 01)
    Subsystem: Foxconn International, Inc. Device [105b:e078]
    Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
    Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    Latency: 0, Cache Line Size: 64 bytes
    Interrupt: pin A routed to IRQ 32
    Region 0: Memory at f0800000 (64-bit, non-prefetchable) [size=32K]
    Capabilities: <access denied>
    Kernel driver in use: bcma-pci-bridge
I found these broadcom drivers on internet:
https://launchpad.net/ubuntu/+source/bcmwl
but I don't know how install them, I only know basic commands.
Information for chili555: http://paste.ubuntu.com/10416148/
Fabby
  • 35,017
You should update your kernel.. I have this same ultrabook and every distribution based on Ubuntu 14.10 and other previous versions fails to work properly with Wi-Fi, Bluetooth and graphics. On the other hand, since the update to 15.04, the new available kernel is 3.19..... This one includes all the hotkeys of the V5-122p, and works perfectly with all of the hardware.
You shouldn't really update kernel unless something is really wrong. Sadly this is the case... Follow this page to update your kernel:
http://www.linuxandubuntu.com/home/linux-kernel-3-19-3-released-install-update-in-ubuntu-linux-mint-other-debian-based-distros
Hope it helps!
