I installed Ubuntu 14.04.02 as dual boot in a macbook pro 2012 13 I noticed that all function buttons works but except those that regulate the brightness of the screen.How do I fix this problem?
Asked
Active
Viewed 3,431 times
I found an answer to this. However I have an iMac 2011, so it could solve your problem.
You need to edit the grub file /etc/default/grub change the line
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
to
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor acpi_osi=Linux"
Then run:
sudo update-grub
Rebooot your computer and voilĂ .
David Foerster
- 36,890
- 56
- 97
- 151
Beshari
- 21
